91 threads found!
ewinemiller | 23 | 1410 | ||
ewinemiller | 9 | 566 | ||
ewinemiller | 12 | 677 | ||
ewinemiller | 3 | 145 | ||
ewinemiller | 1 | 92 | ||
ewinemiller | 8 | 248 | ||
ewinemiller | 14 | 338 | ||
ewinemiller | 4 | 215 | ||
ewinemiller | 4 | 284 | ||
ewinemiller | 0 | 175 |
(none)
ewinemiller | 16 | 1014 | ||
ewinemiller | 25 | 1129 | ||
ewinemiller | 2 | 43 | ||
ewinemiller | 2 | 51 | ||
ewinemiller | 0 | 32 |
(none)
519 comments found!
Hey folks,
So with the code up in github, that might be a good place to publish those. If I get some free time, I can probably export to PDF and dump there, or if someone gets to it earlier, branches, and adds a pull request. There's also a wiki available, but haven't explored the permissions there.
Regards,
Eric Winemiller
Digital Carvers Guild
Carrara and LightWave
plug-ins
Thread: Digital Carvers Guild going open source | Forum: Carrara
And source is now available at https://github.com/ewinemiller/dcg under the LGPL 3.0 license.
Eric Winemiller
plug-ins
And OSX versions are now available along with updated Windows downloads to include DCG Importer.
Eric Winemiller
plug-ins
Thread: Stupid Shader Tricks 3: DCG's Terrain Tools | Forum: Carrara
I love to see uses I never thought of!
Eric Winemiller
plug-ins
Thread: Carrara in Action with DCG | Forum: Carrara
It really is a fantastic work. Please give Nassos, Eva, and the rest of the crew a Like on Facebook.
Regards,
Eric Winemiller
plug-ins
Thread: Liquid in Carrara? Soon... | Forum: Carrara
One of the beta testers was using molecular animations exported from VMD.
http://www.ks.uiuc.edu/Research/vmd/
Regards,
Eric Winemiller
plug-ins
Hi folks,
DCG Importer is out. You can download the demo or check it out at
http://www.digitalcarversguild.com/plugin.php?ProductId=21
It will import sequenced OBJ versions of anything the built in Wavefront OBJ importer will do. By only keeping one frame in memory at a time, it lets Carrara handle large or long running animations.
Regards,
Eric Winemiller
plug-ins
Thread: Introducing Shader Ops 2 | Forum: Carrara
I added a tutorial for the Camera Mapping shader.
http://www.digitalcarversguild.com/tutorial.php?TutorialId=35
Regards,
Eric Winemiller
plug-ins
It won't let the texture be part of the SSS calculation, but you can then mix a texture with what Carrara comes up with. So if you're trying to knock out portions of the SSS or change it in some way, you can use a texture. Very handy for putting that paper label on the outside of a candle kind of texturing problem. Attached is a sample image.
Click on the platform/version you need underneath the Try Shader Ops 2 to get the download you need.
Regards,
Eric Winemiller
plug-ins
Thread: Highlights from different light sources | Forum: Carrara
Quote - Eric, is there any chance that you would consider expanding the functionality of the plug-in to have a sort of a master preset.
It's something I've considered and I have on my list of things to investigate.
Regards,
Eric Winemiller
plug-ins
Oops, missed your first question. I don't think Lighting Control will help with the modeled sky dome blocking GI problem. The slider on LC will let you adjust the intensity of the GI lighting for that shader, but only if it gets to the object.
Regards,
Eric Winemiller
plug-ins
Antaran,
You are correct. There is no way to set it globally.
Regards,
Eric Winemiller
plug-ins
If you want to remove all the light from a particular source, you can use the Restrict Lighting to function for the light. It's on the General tab/section of the properties panel.
If you want to control the specular and diffuse component individually, we offer a plug-in called Lighting Control in the Shader Plus package that lets you adjust Specular and Diffuse contributions of individual lights as part of the object's shader. You can get more details at
http://www.digitalcarversguild.com/plugin.php?ProductId=13
Regards,
Eric Winemiller
plug-ins
Thread: Adding wave to Gradient Shader. | Forum: Carrara
You're pretty much there. Just make sure the Height parameter is set to the center of your object and the Blend is about the height. Here's my shot at it.
Regards,
Eric Winemiller
plug-ins
Feed the Elevation shader into the Color Gradient so your Color Channel looks like
Color Gradient
|__Elevation
Since you're comfortable with photoshop, another option is build the color gradient there and use projection mapping to texture your text.
Regards,
Eric Winemiller
plug-ins
Thread: DCG open source plugins - tutorials backed up? | Forum: Carrara
