2 threads found!
filthian | 4 | 106 | ||
filthian | 21 | 402 |
13 comments found!
yeah i have hexagon...downloaded the free version..havnt tried it out yet...still learning DS4 (on a fast track)...sounds strange maybe ...but this i how i learn...by creating something and finding out what i need to do to create the image in my mind...blahblahblah...i have learned a good amount of DS4 so far...this type of manipulation we are discussing is close to my last steps...
.cr2 seems to export fine...into a empty (but setup with proper folders) "Runtime"
above is result of dform/morphed export as .cr2
below is the working file of corest morphed to my liking (notice the mid section is less sinched)
i used the dformer for this quick manipulation...spawned dformer morph...dialed the morph...n gotta find the proper way to get both the applied morph and clothing item out/saved together...again progress is slow right now do to this thing called life...lol...money makin money money makin...
maybe this is the wrong route to take for this kind of editing...but im thinkn its this close...there has to be a way (im not sure of yet) to make above image a finished clothing item....
til then ...sleep then more work...14days straight right now
Thread: leather corset v4 - by billy-t...fit help | Forum: DAZ|Studio
k...i was trying to use xdresser...
so far i am now trying this....d-form corset on to my shaped genesis figure...hide genesis...and learning about how to export the morphed corset as a clothing item (and get the corset to take the morphs permanently)..and add altered clothing item to runtime...
is this possible...?
as far as i got -- covernt to triAX weight map...then export as .cr2
but .cr2 corset bottom is crumpled...
still working close to 80hrs a week right now..n got a fever....so progress is slow
seriously though thanks for your help
Thread: crossdress...custom created fiugre support...?? | Forum: DAZ|Studio
....to solve this one would need to run the corset thru either cross dresser or ww2 and convert it from v4 to v4 so it has the exact v4 base shape then load and autofit...
--- is there a way to convert v4 to v4
im getting an error = converting same figure - pop up...i tried adding morphs .. but still get the same error
v4 to v4 (with or without morphs) = error = converting same figure
you the man...r woman..not sure just sayn
thanks ...im gonna get right on this and post results as well
really thanks a ton
@SickenlySweete
got the genx working with morphs from corset package...
i created dialed and preset style moprhs...
i implemented the morphs ( both styles) and applied corset with auto-fit...
still poke threw ...in the end of auto-fit the corset seems like its fitting properly and then disappears under genesis figure (with basic female dialed 100% and corset body inj dialed 1.0)
if u have this specific corset clothing item ... please reply... really cant find a fix...
wondering what im doing / or whatis going wrong
also tried transfer utility
i am ...mostly... having trouble getting the dial to have an effect...no effect right now...i did leave the "value" at 0 though then created single morph...going to crank it up and try again...
tutorial comment = ... wish there was a video tutorial...better than the 1 with the text ballons
...im slow at this genx...
peace
iii
...got genx to work...install location was the error...for figure support...im using linux/wine/POL
got an injection morph to work with genesis...for corset body and works perfect...now trying to make a dial morph of corset body...from genx...
any help on "genx how to" or good a location for tutorials would be greatly appreciated
thanks for your help all
what i am doing is....drag n drop inj (full body corset) into...genx...only tab it appears in is the preset tab...then im lost...
hi there...SickenlySweete...im not too savy at the genx...you got a quick how to with that idea of yours...i cant seem to get the genx to "take" the individual inj...however i have never really used the plug in before
k...still busy trying havent had much time lately...wrkin like...38hrs n the last 3 days...lol...anyway...so ...
-possibile hiding body parts...?...sounds good...have to try it ...
-but it is a corset and...im not sure if i can hide only portions of the torso...?
again i will try all of these options and post the results asap...thanks again for the support peeps...awesome feedback
peace
iii
yeah i know about the tutorials...and just found the poke away...gonna make the purchase and ill post the results...thanks for the replies......hopefully good news in the next post
