12 threads found!
floating | 0 | 42 |
(none)
floating | 8 | 266 | ||
floating | 1 | 151 | ||
floating | 1 | 71 | ||
floating | 1 | 91 | ||
floating | 1 | 83 | ||
floating | 0 | 74 |
(none)
floating | 2 | 105 | ||
floating | 1 | 152 | ||
floating | 1 | 207 | ||
floating | 7 | 561 | ||
floating | 4 | 154 |
5 comments found!
thank you all for your suggestions.However, I need something a little more elaborate, with a sash, perhaps, and extra trim. Thanks again.
Thread: Two speakers with Mimic poses | Forum: Poser - OFFICIAL
I would like to be able to transfer vic 3 to max 5.1 and apply morpher modifier to create morph targets so i could animate speech from max directly, however, the modifier also morhs the teeth, with very bad consequences. What I need is a way to edit the vic 3 mesh to eliminate the teeth for the morph, but I am having trouble doing this. Any suggestions? send replies on floatingworld2@yahoo.com.au
Thread: exporting poser 5 into max 5 problems | Forum: Poser - OFFICIAL
You can export sequence of obj files from poser and use freeware to convert to 3ds animation. (see habj site).Try doing an animation with a character in poser pro 4 and exporting using a program called maximum pose II by a guy called conan...very useful(doesn't work for poser5 but this scarcely matters)...exports textures as well..It creates a maxscipt but I don't know if director 8.5 will accept maxscripts.OPf course, if u have max this is no prob. Also you can export DAZ models as meshes in max and use biped to place skeletons in them. Then apply bvh or mocap files to model. Also...expression morphs can be transferred to max by exporting different expressions as morph targets,importing into max and then using morph modifier to act as expression dials. Hope this helps.. David
Thread: BVH motion files | Forum: Poser - OFFICIAL
try life forms 4 from credo interractive. They have a rotoscoping favcility for generating bvh files from live footage but it involveds lining uop a figurine with the figure in the avi.
Thread: Michael 2 eyebrows problem giving me an ulcer. | Forum: Poser - OFFICIAL
Thread: cardinal's outfit | Forum: Poser - OFFICIAL
