12 threads found!
fuli42 | 12 | 111 | ||
fuli42 | 5 | 134 | ||
fuli42 | 2 | 109 | ||
fuli42 | 6 | 64 | ||
fuli42 | 6 | 112 | ||
fuli42 | 13 | 219 | ||
fuli42 | 2 | 39 | ||
fuli42 | 9 | 107 | ||
fuli42 | 2 | 60 | ||
fuli42 | 1 | 147 | ||
fuli42 | 2 | 28 | ||
fuli42 | 8 | 32 |
27 comments found!
JayPeg! You can assign keyboard shortcut for an action. You can even select between several options to START an action. If you don't have anything useful to add, why bother posting?
Thread: Shortcut for playing and continueing an action | Forum: Photoshop
Retrocity, Thanks, excellent idea doing the rotation. I made an action that does about 30 steps, I need to intervene @ steps 5. 16. and before the last. I am going through about 100 pictures per day with it. I am looking at scripting PS myself, anything that would cut down the processing time THanks for the help Fuli42
Quick reference card: No it does not tell me that there is a keyboard shortcut for playing an action. It does not say that you can assign keyboard shortcut to actions either (which you can). I actually keep the quick reference card next to me when i'm working, and do all that is possible with shortcuts.
Yeah, I looked in the Photoshop Bible and Photoshop Foundation (both for 6), but nothing. (I upgraded to 7, but...) Anyway, another question: Any shortcut for Canvas Rotate? THanks Fuli42
Thread: Equipping an office for my characters | Forum: Poser - OFFICIAL
Thread: zebra pattern | Forum: Photoshop
Thread: CSS positioning - not too dangerous | Forum: Photoshop
thanks for the infos! I'll try these out soon. I didn't much luck with transparent gifs with imageready, i hope it'll be as easy as it sounds. thanks I've playing with slices and CSS, and had very little problems. With Netscape4, when you create a rectangle, and you set the slice option as 'No image', and you write some text, the rectangle will collapse around the size of the text, and will not take up the size of your original rectangle.Its color will not show as a result. This is a bug in Netcsape though (it does not support the height property of divs for example). You just have to make sure that the divs, that contain text, are filled with 'something' (a table for example). The table has to be the size of your rectangle.
I've let ImageReady use CSS to position the slices. I've looked at it with a Netscape 4.6 , IE5, Opera6 used all every kind of text display size on the browser, and the slices stayed true! I've tried to do some DHTML on the site, but I could not hide/expose the layers (slices) with the tables version. It worked on Netscape but then not on IE, then it worked on IE but parts were showing. Thanks for the advice! Topstyle is the tool that I've always used for stylesheets (with Homesite for html/javascript), I didn't know they've had a 3.0 version out. ImageReady is a great tool, even if I want save a simple GIF I use to go over to ImageReady, they come out much nicer with it. One feature I am missing (sort of) is the possibility to create transparent areas on a GIF image. Yes, I've read the manual, theoretically it's possible, but still I can never get it right, so I still have to sometimes go back to good ol' PaintShop to do transparent gifs.
Thread: Antialias | Forum: Photoshop
Thread: effect question | Forum: Photoshop
Thank you Ken! I am very close now... I've been experimetnig with applying the effect for each letter, separately. It takes a lot more time, but with the actions... but still takes a lot more time. I am doing the opposite now. I am working, but pretending not to work (I am on holiday for 3 months in Marseille!) Cheers! Balin
I'm sorry, i've tried to follow your guides but still no chance. You've motion blurred the text selection in quick mask mode,then cleared in selection mode? I assume you did it before applying the radial blur. How about the outer glow style? Please could you give me some more hints? Thank you Fuli
