1 threads found!
gabrielxdesign | 27 | 1346 |
15 comments found!
Thread: Upgrading to poser 12? | Forum: Poser 12
I'm working with the two, Poser 11 and Poser 12. Poser 12 does nice stuff, but it's kind of buggy if you're going to use your Poser 11 files, since they won't render better for now.
Thread: P11 vs P12 Superfly | Forum: Poser 12
ghostship2 posted at 2:19PM Sat, 14 November 2020 - #4404536
set clamping to 0 and see if the highlights become brighter.
I'll try, thanks!
Also:
Update: Got this from Support
There's a known issue with the Blinn and Phong speculalarity nodes in SuperFly. This is the cause of the flat looking skin and will be addressed in the next release.
Well, I changed my main model to Base La Femme Simple PBR in Poser 12 and it looks better, I like how the face is rendering, but not the neck and body. I'm missing that nice highlight in the neck/collarbone, looks more realistic in my Poser 11 render. I guess it's nothing I can't change in Lightroom (post). At this point I don't know if I should wait for new patches or get into the idea of modifying my models and variations to a "P12 version".
ghostship2 posted at 3:43PM Fri, 13 November 2020 - #4404476
@gabrilxdesign The default La Femme shaders work just fine. Why not just use those?
Because I have dozens of models with dozens of variations, and none use default stuff. I would have to copy and update hundreds of files just to make them work "fine" in Poser 12 since not even default La Femme convince me right now. Sounds like a lot of work I didn't think I should do. Default can be fixed with more lighting though.
Thread: Poser 12 flagged as ransomware | Forum: Poser 12
Thread: P 12 issues already | Forum: Poser 12
Y-Phil posted at 8:45PM Sat, 07 November 2020 - #4403740
gabrielxdesign posted at 11:03AM Sat, 07 November 2020 - #4403678
Guys, you should contact Poser Support with these issues, the more we help, the more they can fix: https://support.posersoftware.com
Too late ? It's corrected in Poser 12.0.276
Oh, ya, I just saw the last patch notes. I'm waiting, the bugs affecting me are next:
You're welcome. They tested a scene I sent them with my model (above) and with it they found 2 bugs, they said those are now high priority for the next patch. So hopefully it will be fixed soon.
ChromeStar posted at 4:37PM Sat, 07 November 2020 - #4403690
Thanks for sharing that. I would rather hear that it's a bug they intend to fix than a deprecated feature we will have to work around, or a deliberate change. That makes me more optimistic.
Update: For those having these issues like me, support told me they found the bugs and will fix them, also:
There's presently a work around but it's awkward. If you greatly increase the "scale" values on all the scatter nodes that will help the glowing eyes look.
The second part is the Blinn node is totally broken. (also a high priority bug) for the moment you could use a specular node in it's place but it would look different.
Update: I'm working this with the Poser Support team, they say they didn't expect this drastic difference. I'll keep you guys updated :)
Hi, tried that, but didn't work anyway, sadly.
ghostship2 posted at 12:29PM Wed, 04 November 2020 - #4403205
one thing to be aware of, and I think this is a bug: Post render denoise is ON by default even though the box is not checked. You have to toggle the box on then back off again to turn it off. As of this moment I have not found the denoiser to be useful at all due to the way it destroys detail in the skin and makes the render look cartoonish or look like it's a Photoshop painting. Maybe they'll have controls for it soon so we can adjust how strong it works.
You're welcome. Yup, I hope a solution soon, honestly I thought "Early Access" was going to be more like, "testing new features" and not "it won't render correctly".
Rhia474 posted at 12:03PM Wed, 04 November 2020 - #4403201
Yes, but this is a great side by side comparison. Thank you for posting it. Hoping for some sort of solution.
Thread: Paypal without Credit Card? | Forum: MarketPlace Customers
Hello, if anyone is having issues because the "place order" button doesn't enable and you are paying in a non-US country, the issue is the ZIP code. I already told the devs, but it case they haven't fixed it yet:
You will notice that you can fill your credit card things, or use the PayPal section and the button will be enabled.
Thread: Poser 12 exporting render problem | Forum: Poser 12
