2 threads found!
gilbabin | 5 | 183 | ||
gilbabin | 2 | 111 |
9 comments found!
Thread: VWD 2.2 Release - Installation and usage thread | Forum: Virtual World Dynamics
Hello, I purchased VWD v1 some time ago, and use it often to make dynamic hair in POSER, and it's great :) (I don't use DAZ)
There is a great feature in POSER that allows to begin a cloth simulation at frame x and to stop it at frame x+x: Example : in animation, I often make animation sets of 500 frames until sometimes more than 1,000 frames. It's important for me that I can be able to begin a simulation at frame 100 and stop it at frame 400 (just an example) . I couldn't find a way to do that with VWD v1 and it currently prevents me from using VWD for cloth simulation Is it available within v2 (for POSER obviously) ?
Also: I usually setup a dynamic hair for an animated character (it is sometimes difficult to do) and change the animation or some parts of it. I would be happy to have a "one click" process to redo the calculations for a new animation (assuming that the start point is exactly the same)
Is there a way to save a vertices set on a specified character (skull cap for example) in order to re-use it for another animation? (I mean an easy way like to have it in a library)
Currently, I still hesitate to purchase v2 because of these limitations found in v1...
Thanks for any answer :) :
Thread: Obtaining Latest Version | Forum: Virtual World Dynamics
Yes, if I can do something ... please, tell me what you need ?
PS : I don't use DAZ3D and work only with POSER.
Hello Gerald, I purchased VWD v1.1 in oct. 2017 ... I also would be happy to obtain latest version ?
Thx in advance,
Thread: Problem with procedural planet ? | Forum: Vue
Thread: Problem using imported Poser animated file in a VUE 6 scene ! | Forum: Vue
Thx for the answer !
The second problem occurs only with a multi-characters poser file (3 in this case).
I also used some dynamic clothed single character without problem...
I also tried without success to import more than one poser animated file : it seems that only the latest retains its animation ... but I need to test more I suppose ?
