13 threads found!
hborre | 6 | 304 | ||
hborre | 8 | 968 | ||
hborre | 16 | 1019 | ||
hborre | 10 | 503 | ||
hborre | 0 | 202 |
(none)
hborre | 6 | 376 | ||
hborre | 12 | 764 | ||
hborre | 24 | 645 | ||
hborre | 12 | 375 | ||
hborre | 79 | 3334 | |
hborre | 4 | 282 | ||
hborre | 13 | 363 | ||
hborre | 47 | 975 |
13,227 comments found!
Another simpler alternative is to locate the texture file for the shirt and open it in a third-party graphic program. Create the design in a separate layer and position it exactly where you want it. Merge the layers and save the image as a .jpg or .png file under a different name. In Poser, replace the original texture file with the one you created.
Thread: My own designs on t shirts? | Forum: Community Center
The shirt's mesh should have a UV template associated with it which is normally found within the object file. If such a template does not separately exist, you might need to rely on a third-party app to unwrap the object file and save the template as a .jpg file. The .jpg image will need to be opened in another third-party graphics program so you may place and center the design of your choice. It is best that you have a high-resolution image or text for it to be legible in the final render.
Thread: I couldn't see the color preview anymore...... | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
This is a nice presentation, but the OP is running P11. It may be beyond his understanding of how it is done in P13.
Thread: new poser manual not here yet. | Forum: New Poser Users Help
Clear your browser cache and try again. If that doesn't work, visit Posersoftware.com to download the PDF for the Poser 13 Manual. Please note that the PDF manual is 910 pages long.
Thread: figure Cookie into poser 13 and I can't see it in my workspace | Forum: Poser - OFFICIAL
According to DAZ, Cookie is a Poser item because there is only 1 Poser Core installer listed on the webpage. Unless the runtime was removed or relocated, it should work.
Thread: Looking for - Vechicle similar to chitty chitty bang bang. | Forum: Community Center
If you are stuck for an actual replica, there is one here: Chitty Chitty Bang Bang - Download Free 3D model by Matt Dixon (@the1stdog) [52ab0e7].
IBL fails to render in Superfly. As previously noted, the Envsphere prop and the snow emit ambient light; without it, the scene would be entirely dark. This can be confirmed in the Material Room.
Thread: RAM quantity (GPU) | Forum: Poser 13
Choosing the right render engine for your final image, be it Firefly or Superfly, is crucial. While you've received suggestions from previous posts, the type of content you're using, the currency of the Material Room shaders, and the density of the scene's population remain unknown.
RAGraphicDesign posted at 7:19 AM Thu, 14 November 2024 - #4491331
Overwriting the original file is safe provided you do not resave your scene. Initially, verify the presence of lights in the scene at render time. If lights are present, examine the Properties for each to ensure they are active, as indicated by an 'On' checkbox, signifying the emission of rays. Next, confirm that the light intensities are set above zero. Lastly, if there are no lights, add one to monitor its effect.RedPhantom, But the render came out like this......
I'm afraid of touching something I shouldn't: I would like to keep the file to be able to use the scene for other things....
As mentioned earlier, if you're using a dome, scene illumination can come from the ground and background. This can be verified in the Material Room. When using Firefly rendering, navigate to the Material Room and examine the Ambient settings on the PoserSurface node. If the value exceeds 1, then the background is contributing to the scene lighting.
My overall assessment indicates that the lights are off, and the snowy ground and background emit an ambient glow that is not apparent at full render. Please verify if any lights are present throughout the scene and whether they are activated.
Thread: actual parent for actor? | Forum: New Poser Users Help
You could morph him into a teen by scaling particular body parts, but getting the proportions right and having the clothing fit is tricky.
Thread: Just an observation...the Reload Textures function is not working. | Forum: Poser 13
I would not be surprised if something may have broken when implementing other changes to the Material Room. This feature is not commonly used so it could have been undetected for quite some time.
