Community Center F.A.Q (Last Updated: 2025 Feb 10 11:31 pm)
The shirt's mesh should have a UV template associated with it which is normally found within the object file. If such a template does not separately exist, you might need to rely on a third-party app to unwrap the object file and save the template as a .jpg file. The .jpg image will need to be opened in another third-party graphics program so you may place and center the design of your choice. It is best that you have a high-resolution image or text for it to be legible in the final render.
Another simpler alternative is to locate the texture file for the shirt and open it in a third-party graphic program. Create the design in a separate layer and position it exactly where you want it. Merge the layers and save the image as a .jpg or .png file under a different name. In Poser, replace the original texture file with the one you created.
Is it possible to manually design new patterns on tee shirts so my characters willl convey any message appropriate to my story?.
drawn
