11 threads found!
ima70 | 8 | 376 | ||
ima70 | 5 | 134 | ||
ima70 | 9 | 152 | ||
ima70 | 2 | 115 | ||
ima70 | 6 | 141 | ||
ima70 | 7 | 714 | ||
ima70 | 3 | 142 | ||
ima70 | 4 | 106 | ||
ima70 | 3 | 139 | ||
ima70 | 10 | 219 | ||
ima70 | 14 | 149 |
261 comments found!
Thread: Bulging deltoids in Mike 3 clothing, was there a solution? | Forum: Poser - OFFICIAL
That looks great, can it be downloaded? I have D3wm,V3wm and M4rrWm but not M3rrWMYou can try my Weightmapped M3RR.
It's the Reduced Resolution mesh, but it should be easy to transfer M3 characters faces over to M3RR in Poser.
It also wouldn't take long to at least weightmap M3's shoulders.
(You can also try to transfer the weightmapping from my M3RR over to regular M3, but you would have to smooth out/edit some of the weightmaps because of M3's higher resolution.
UPSCALING is always more difficult than DOWNSCALING a weightmap rig.)
BTW, I think I also have an M4toM3 figure lying around somewhere, that I made from all M4 mesh.
Let me see if I can find it.
Thread: Nea 3 makes a step back | Forum: Poser - OFFICIAL
Thread: Apollo Maximus is BACK!!! The Optimal 3D Figure. | Forum: Poser - OFFICIAL
Thread: White Artifacts ~ Lighting | Forum: Poser - OFFICIAL
Thread: Need a rigged character for tutorial | Forum: Poser - OFFICIAL
I think Sixus has some open source characters, just search here:
http://www.sharecg.com/pf/Sixus1Media
Thread: Playdoh Hair | Forum: Poser - OFFICIAL
Maybe some of this?
http://www.renderosity.com/mod/freestuff/details.php?item_id=56293
http://www.renderosity.com/mod/freestuff/details.php?item_id=50985
Thread: Nea 3 - detail work | Forum: Poser - OFFICIAL
Thread: adMan, a free male figure for Poser nearing completion... | Forum: Poser - OFFICIAL
Thread: Help with Glass in Poser5 Please | Forum: Poser - OFFICIAL
Quote - IIRC, has it been noted that translucence does not work correctly in P5?Â
In P5 times, I did some use of translucence chanel and it did what it was supose to do, maybe there was a confusion between translucence and SSS :-S
Tray Difuse_value+refraction_value=1 this seam to work better, and why are you using a diferent mat for the undertable? I think that if all table mat are the same it shoud look way better.
Don't use transparent in png format for poser, since poser don't "see" them as transparent as Blender 3D or maybe other aps does.
Thread: Poserizing Models? | Forum: Poser - OFFICIAL
http://www.renderosity.com/mod/freestuff/details.php?item_id=23836
This lightball maker may help if you can't setup you lights, but you won't get the projection of the screen over the wall, for that you must conect the same texture as the screen to an spot light and place it the way Mrsparky say.
Black is Zero, no refraction, white is 1 full refraction, if you plug a color texture, it will be considered as a grayscale, and P5 math nodes will work in higher versions.
Can you please post a capture of your material?
Sorry for not answering before, but I'm at work, wimvdb has helped you a lot :-)
For reflection I loaded BB EnvSphere deleted all nodes of its material and plugled a latlong env map directly to the alt difuse channel.
now for the color try to increase the difuse value and decrease the refraction value, always trying to keep the total of the value in 1.
of that dosent work for the dark decoration try pluging the texture to the refraction value since they are very dark (near to zero) they should lead to no refraction.
Sorry my english but I'm in a hurry at work.
Post your results please :-)
