4 threads found!
javajimg | 6 | 425 | ||
javajimg | 15 | 266 | ||
javajimg | 3 | 205 | ||
javajimg | 1 | 126 |
4 comments found!
I went to create images and now the two programs are rendering the same. I cannot account for what happened. I was not imagining things, and I have the cached renders in both programs to prove it, but for now, things seemed to have fixed themselves. I guess this was one of those issues where the solution is restart the machine and try again.
Thread: Looking For Hair Dryer | Forum: Poser - OFFICIAL
Thanks for all the replies on this topic. I did a little experiment and hid the hair part of the curler prop mentioned above. I then did some fiddling with the curlers to try to fit them properly around Victoria 4's head. I only moved a couple of curlers, but it looks promising. I can change the color of the hair around the curlers using Photoshop, so now all that is missing is the hairnet. If no one has a hairnet, if anyone has a shower (or bathing) cap prop, I may be able to get that to work by fiddling with the texture.
Once again thanks for all the replies on this topic.
Jim Gantt
Quote - Here's a fairly simple one. Properly sized and fitted to typical figure,
and the head-part is adjustable. You may want to add a cloth texture to the
seat, and a wood tex to the armrests.......
Thanks. That is exactly what I am looking for.
Jim Gantt
Thread: Poser 7 and Poser 5 | Forum: Poser - OFFICIAL
Quote - Yes to both, although uninstalling P5 after having installed P7 may cause Windows to lose the file associations for poser files.
I did that, and had to run the installer for P7 again because none of my pz3s were connected to Poser anymore and I couldn't get Windows to accept it as a program to open the files.
Thanks for the info.
Jim Gantt
Thread: Poser 13 Firefly Render Different From Poser 12 | Forum: Poser 13
