12 threads found!
jroulin | 0 | 63 |
(none)
jroulin | 2 | 182 | ||
jroulin | 0 | 37 |
(none)
jroulin | 3 | 42 | ||
jroulin | 0 | 24 |
(none)
jroulin | 1 | 40 | ||
jroulin | 2 | 39 | ||
jroulin | 3 | 49 | ||
jroulin | 3 | 65 | ||
jroulin | 1 | 37 | ||
jroulin | 1 | 28 | ||
jroulin | 8 | 224 |
172 comments found!
Thread: Dynamic Clothes WIPs for La Femme 2 | Forum: La Femme 2
Thread: Poser 6 'Cant open script for reading' (runPythonScript from CR2) | Forum: Poser Python Scripting
Thanks for the explanation odf having the back layer invisible is a good way not to have pooks visible. I need to think about it.jroulin posted at 11:12 AM Thu, 22 August 2024 - #4488632
Easy, I hem all my garments, but instead of folding the fabric in, I create extra pattern pieces to be sewn under the main fabric. That allows me to assign a separate "hem" material and make them invisible in Poser because a small amount of poke-through is bound to happen.Hi odf they are really looking great!
I just have one question; how do you do your cloth thickness? Are you using the piping in MD2? I was giving up on that as I did never archive good results and do them in Hexagon in a second step.
Here's what the pieces, sewing and internal lines look like for the waistband in the skirt above:
Well I will have a look at it when I find a little time. If I find something I will post it here. Maybe it is also simply not posible to do it.
Lets make it short did you find something like that? The v 3158 ..... are the vert that are in the groupe and they needs to be present in one of those or nothing will happen
vertsGroup _constrained_
v 3158
v 3733
vertsGroup _softDecorated_
v 565
v 566
v 567
v 568
v 569
v 603
v 604
v 605
v 606
Oh just one question, how did you open the pp2 file? I remember that the UV coordinates for the different groupes are not showing if you open it with PoserED. To see what happends you need to open it with a standard text editor.
Never tried it that way but from my experiments it could work. I think you should be able to add all the none constrained verttex in the default group in a pp2 file. It should overwrite the groups so no need to add a pose with it. If you do so the bad boys can also use it if they want to have nude shoulders and more. I would do two files one no constrained and one constrained so that the user can switch back to the default values and in this case the vertex needs to go in the constrained.
That set is very nice odf! I will surly download it as soon as it hits the free section.I'm getting back to this silly frilly thing which I hope to stuff into FreeStuff soon. Do you think this image here would work as a thumbnail/promo without having to tick the nudity box, or is it still too transparent?
Hi odf, was getting you free cozy outfit for LaFemme2 and big surprise there is already an Easy sim for it included. Thanks for all your free items that are working so nicely.
Thread: I don't seem to have many clothes for la femme 2??? | Forum: La Femme 2
All of my dynamic clothing for LaFemme2 are coming with an easy simulation script. All what you have to do is to load LaFemme2 and pose here. Add the clothing and hit the EasySimulation icon that is in the simulations folder of the clothing. The script will then set up the full simulation for you and calculate all the frames. When don simply go to the last frame and render.
Well not really if you tweak the settings, it will keep those values. What I do in this case is deleting all the simulations and start the script again so that it is loading the simulation at the default values. That said making a script that deletes the sims should not be too difficult.
