We couldn't find any threads matching the specified search criteria.
2 comments found!
Attached Link: http://www.alienspeek.demon.co.uk
first of all make sure you are using the monitors correct drivers, then with this profile configure photoshop > Edit color settings > in here will be a number of options i use the default web graphics > you will see a short descripton as you roll over the options which explains what it manages, i would also calibrate your monitor and graphics card > most modern graphics cards allow you to change the color temperature and contrast (gamma) this might also help the reason its important to use the correct monitor drivers is that photoshops internal color drivers use the basic standard and if your monitor is using the correct drivers everything should be working just fine :)))Thread: Okay a dumb question but hey I need to know.. | Forum: Photoshop
There is an amazingly easy way to do this IF the object images whatever are on a transparent background .. just go to > Select > choose load selection and however complex it will select the entire outline .. choose new layer and stroke under > Edit > link the new stroked path to the layer it was selected from ... that way you havent stroked the origional layer.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Thread: Color Setting Question in PS 6.0 | Forum: Photoshop
