19 threads found!
keithw | 7 | 177 | ||
keithw | 59 | 1509 | |
keithw | 19 | 377 | ||
keithw | 7 | 274 | ||
keithw | 4 | 262 | ||
keithw | 1 | 84 | ||
keithw | 2 | 128 | ||
keithw | 2 | 148 | ||
keithw | 5 | 33 | ||
keithw | 10 | 46 | ||
keithw | 2 | 13 | ||
keithw | 5 | 17 | ||
keithw | 4 | 17 | ||
keithw | 1 | 8 | ||
keithw | 3 | 28 |
229 comments found!
Thread: Target Weld | Forum: Carrara
I've been trying to target weld vertices on a sphere created in the vertex modeler. Some of the time I can select the vertex I want welded and sometimes I have to try 10, 20 times to select the first vertex. Once the first vertex is selected, I can usually select the second vertex. I thought that I might be doing something wrong during the selection process. I have no problems selecting vertices using other tools. I am using my old slow computer. It's a Pentium 4-2.8GHz with 1GB of memory.
Thread: Import Adobe Illustrator file into vertex object | Forum: Carrara
What I do, is import the ai file into the spline modeler and then use the "Convert to another modeler" feature. It's under the edit menu. I some times have to play around with fidelity to get what I want.
I too would like to be able to import directly to the vertex modeler.
Thread: Carrara vs Cinema 4d ????? | Forum: Carrara
Comparison charts as well as any literature on a product  is advertising.  It meant to show the product in it's best light.Â
The question is not which software is better, it's which software best meets my requirements.
Thread: Cannot move objects in C6pro. | Forum: Carrara
Could it be that your Caps Lock key is on. I just spent over an hour trying to move an obect using the move manipulator tool. the hot point would move but the object wouldn't. Then I noticed the Caps Lock key was on. I turned it off and move tool worked fine.
I hope this solves your problem.Â
Keith  Â
Thread: Carrara used for commercial | Forum: Carrara
Voted for you. Great animation. Checked out the competition and think you have a very good chance of winning. Keep us informed on how well you do.
Keith
Thread: I couldn't help myself (Fred Flintstones Car) | Forum: Carrara
Thread: What are the 5 things you like most about Carrara ? | Forum: Carrara
I like the interface, the fast rendering, the vertex modeler, the shader editor, and bones A feature that I would like is a customizeable menu for the right mouse button.
Thread: Need an opinion on an image WIP | Forum: Carrara
Thread: Immerse your creations into a free 3d game engine | Forum: Carrara
Jerry, Thanks for the link. I don't consider this type of message as SPAM. Jerry is not trying to sell me anything. He just wanted to share a site he thought we would be interested in. I'm interested in trying the software just to see how my Carrara models would look in a 3d game. Keith
Thread: The Bird and the Egg. Anyone remember? | Forum: Carrara
Thread: Vertex Object question... | Forum: Carrara
For got a step. You need too loft the 2 circles as well to create the tube through the cube.
Are you looking for a way to create a cube with a cirlular hole through it? If thats what you want it's easy to do in the vertex modeler. I made one in a couple of minutes. What I did was; first create the Square. then create the circle for the hole in the same plane as the square. empty both. Next loft the square and circle. This will give you a square with a hole in it. Next duplicate the square with the hole and move it up to the desired height. The last step is to select the 4 edges of both squares and loft to connect them. Keith
