15 threads found!
mariajudyta | 1 | 139 | ||
mariajudyta | 2 | 198 | ||
mariajudyta | 1 | 167 | ||
mariajudyta | 0 | 104 |
(none)
mariajudyta | 5 | 211 | ||
mariajudyta | 2 | 52 | ||
mariajudyta | 7 | 146 | ||
mariajudyta | 26 | 356 | ||
mariajudyta | 3 | 95 | ||
mariajudyta | 8 | 256 | ||
mariajudyta | 9 | 120 | ||
mariajudyta | 3 | 811 | ||
mariajudyta | 2 | 144 | ||
mariajudyta | 17 | 404 | ||
mariajudyta | 10 | 375 |
15 comments found!
Thread: Which "freebies" can I use in Poser 7 without having Victoria? | Forum: Poser - OFFICIAL
another question - what does that mean - >>theres a figure bundle.  It does not include the morphs<< ?
Thread: Vue doesn't import whole poser file | Forum: Vue
hello, well....
I reinstalled poser and then made the same figure and imported it again to vue: body was still missing.
Then I've tried it a second time as object file - vue couldn't find any texture - so I had to locate all the 29 textures manually and apply them to the figure.
Complicated, but it worked. I hope, I can present my new picture and solve the problem with poser soon.
It looks like poser doesn't work right any more.
Because now, when importing to vue - it isn't able to find certain textures.
I will uninstall it and try by new installing and tell you if the problem still exists.
I hope not! Or otherwise I'll get mad :o)
I guess something's really wrong with poser.
The first time, I saved the poser file als OBJ-file and imported it into vue, I could see the bodySHAPE, but from the head downwards everything was BLACK. - the textures were missing.
Only the pants were perfectly visible.
The second time, I imported the file into vue, the hands were gone, I could see this on the black shape....
OMG
hello again!
it has definitely something to do with poser!
because - I've made two other figures and saved them as a normal poser file.
Then imported them to vue - in the first one only the head and hair are visible, in the second one - only the hair (???)
Then I tried to reopen them in poser - and indeed - poser also only opened the head and hair - no body is visible.
Why?
hello!
well, I also thought, maybe its because vue is running out of memory, So now I restarted vue, and loaded only the poser-woman, without any other things (landsape/interior).
But the body is still missing.
I checked the properties panel in poser and everythings checked on >>visible<<
I'm really hopeless - what can I do now? I'll try to import another poser file and look whether vue will import everythin or not.
It is called JESSIE and she's in the gun-fight pose.
But when I render the poser file, the arms are stil there, they are only missing in vue
It seems like the whole body is missing in vue, but due to the fact that the woman is dressed, it looks like only the arms are missing - only the head and neck is visible.
Where can I see whether a "transparency map" is applied?
Mariajudyta
Thread: I cannot GROUP my objects: hair, body & clothes - please help me ;-) | Forum: Poser - OFFICIAL
Hi, I tried but it doesn't work.
When I select the "dress" and go to -conform to- I can't find the figure, only the hair... :-(
But I also think that you misunderstood me, I don't simply want to "adjust" the things - I want to FIX them - so when I move the head, the hair move too.
Thread: Where can I find free textures / materials for vue? | Forum: Vue
Thread: I need "Victoria 4" for my Program | Forum: Poser - OFFICIAL
Hi and hello,
another problem - for example, when I want to download another figure/morph for victoria (http://www.most-digital-creations.com/freestuff.htm) it is a zip.-file.
Where should I unpack it to? To which destination? I tried directly to poser, to figures a.s.o. but I cand find or open it.
Thanks for your answers.
Mariajudyta
Thread: How to make foam on the water shore? | Forum: Vue
