5 threads found!
mattilis | 4 | 168 | ||
mattilis | 23 | 463 | ||
mattilis | 2 | 61 | ||
mattilis | 3 | 110 | ||
mattilis | 5 | 241 |
15 comments found!
U should (or must) use another 3D Application to convert such as Max, Maya before working with MED Use Optimue in max to convert ur model to lores
Thread: Searching for some figure... | Forum: Poser - OFFICIAL
If there aren't any FF Model...I think I will try create some Morph and Re-texture them...
Thread: Dynamic Clothing: | Forum: Poser - OFFICIAL
if u give more detal...I can help you...print screen ur setting and post it...maybe I can understand what happen here
Thread: Creating thumbs for Poser with P3dO - the easy ways | Forum: Poser - OFFICIAL
Thread: Where the path to Bat Lab | Forum: Poser - OFFICIAL
oopss....I understand the matter...Fortunately, I have download a lot of them...:D They have a lot of new item and have launch it to Marketing Place...These items are too cheap...
No...What I remmember is a login page...So, you can login with your account and then...you can access their wonderful free stuff Anyone knows???
Thread: Getting Morph's from Rhino to Poser - I need Help! | Forum: Poser - OFFICIAL
I don't know but from my exprerience...you must preaprare your model before morph...I have encounter many problem as u... Compose can be downloaded from free stuff and easy to use...but It need Java Runtime Enviroment from Java
Do u use compose to prepare morph or export directly from poser..If you export from Poser...It will not be sure that the Morph will work correctly... Compose can be found in free stuff
Thread: animation | Forum: Poser - OFFICIAL
Thread: Win2000 & Poser 5 | Forum: Poser - OFFICIAL
I m using window 2000 professional server in my company with poser 5 and don't have any problem
Thread: Uzilite skirt - making it longer??? | Forum: Poser - OFFICIAL
Thread: Yucky Texture part 2 | Forum: Poser - OFFICIAL
more hight light and self illuminum will make it better... I think the bump map is quite good, but u should make the edge more smooth....
Thread: Chest rotation with M3 SR1??? | Forum: Poser - OFFICIAL
I still use Mike 2., alhouth i have bought mike 3...cuz Mike 3 have some weird joint paramter..:D
Thread: Item imported from max turns black in poser 5 | Forum: Poser - OFFICIAL
No, that is not so weird... I have met this when making a sailor skirt...the colar turn into a black hole... When making model in max..the terrible thing is 2 face model... But if i find out a way to elimiate this in max...The UVMapper u use in Poser...is a kind of Multi-Sub object Material in max...so, just apply it in Max and u will not encounter any problems in Poser..
Thread: Need help! | Forum: Poser - OFFICIAL
Morph preparation is very important , It take me months to learn how to prepare model for morphing.....:D First, U should use the original obj file, not the obj exp from poser...cuz the model from poser sometime don't have the same verices with the original... Second, Use compose to Prepare ur model...using compose is not too complicated but it take time to understand it (compose is in free stuff, U will need java enviroment to run it cuz it is a jar file) Third, Import to ur 3d app If u use max, u should check scale 1000, rotate model in obj imp plug from habware if u use Amorphium, Imp and Expt ur model, then ReImp the model u exp from Amorphium, cuz Amor have a strange thing..it reserves all ur vertices ----------------------------------- ----Hope help-- PS: I can't remember where can find these tut...some is my exprience, but some is from some one else
Thread: Poser and 3D Game Studio | Forum: Poser - OFFICIAL
