216 threads found!
mdbruffy | 7 | 444 | ||
mdbruffy | 18 | 514 | ||
mdbruffy | 4 | 345 | ||
mdbruffy | 25 | 1525 | ||
mdbruffy | 9 | 537 | ||
mdbruffy | 3 | 361 | ||
1 reply with content advisory
mdbruffy | 30 | 2035 | |
mdbruffy | 13 | 617 | ||
mdbruffy | 22 | 1109 | ||
mdbruffy | 1 | 505 | ||
mdbruffy | 2 | 148 | ||
mdbruffy | 8 | 458 | ||
mdbruffy | 3 | 337 | ||
mdbruffy | 6 | 333 | ||
mdbruffy | 26 | 1165 |
1,168 comments found!
Okay. I'll try to remember all of this for next time. Thanks.You can also right-click any Library folder and click "Show in Explorer", if you're on Windows.
Thread: Where is it? | Forum: Poser 13
mdbruffy posted at 8:53 PM Fri, 19 April 2024 - #4483823Found it. Thank you.Sunfire posted at 8:41 PM Fri, 19 April 2024 - #4483821If you're ever curious where things exist, in the Lirbary enable the Extended Details Panel (found at the bottom of library if you click the 3 dots). it will show you the filepath and it even provides a button for "Show in Explorer" to make it easier to go to. As far as I've seen it works the same for both official and custom runtime locations, so hopefully that will answer your question and be useful in the future.I'm looking at Local Disc (c:). Program Files > Poser Software > Poser 13 > I do not see a purchases tab. I see a Runtime folder, then a libraries folder, but the only thing in that is an empty collections folder.ÂIn the program you will find a purchases tab with the library. Click on it, then click on included and download from there. It will install into a directory called included. It is also where you will find the default content that installs with Poser 13.
I'm looking at Local Disc (c:). Program Files > Poser Software > Poser 13 > I do not see a purchases tab. I see a Runtime folder, then a libraries folder, but the only thing in that is an empty collections folder.In the program you will find a purchases tab with the library. Click on it, then click on included and download from there. It will install into a directory called included. It is also where you will find the default content that installs with Poser 13.
Thread: Library Trouble | Forum: Poser 12
Reinstalling an older flash version should actually work, it worked for me on all machines. Win Updates do not remove it no Time machine needed , as alternative you can also use " Adobe AIR, with settings to external Library ".
Well, it didn't work on mine. I went ahead and removed it. deleted the files and all. This is the kind of relationship I've always had with Poser. Some versions work for me and others don't. I had the external library in place, but I wasn't happy with it. Whenever I tried to do anything, it disappeared till I was done. I'll jjust have to gowith Poser 12 and hope I never have to convert any more outfits.
how do you get that? If Poser had bought the program, they would have had all the necessary files to handle things- including support and updating.Purchasing PhilC's program would have resulted in a loss of customer support for us. Given that he has passed away, this support would no longer be available.
I had reinstalled Poser Pro because it was the last version to have Wardrobe Wizard. Poser should have bought Phic out when he retired instead of pulling the app out. Now we're stuck with Poser 12 and up and their lousy conversion app.... and Flash will never work again. Thanks Adobe. So, unless you have a time machine to go back before 2020 you're probably out of luck. That's why I said it was a miracle it was doing any thing, If you want a normal library you'll have to update Poser to a Post-Flash version. Poser 11 and up
The only other solution I know is the p3do library system. It runs in a separate window and is a windows native app so no flash nonsense. But, it definitely doesn't look anything like Posers normal library.
Backfire2024 posted at 9:35 AM Sun, 14 April 2024 - #4483589
I just looked again. There is no sample folder. Only the 3 I listed.I don't have a folder with my user name- just my name.Sample stands for your user name account :)
Found it. It WAS in the folder with my name on it.
It reset, but there's still a problem. It all comes back to Adobe Flash not working anymore.
Got the install file but it wouldn't install. "We have retired Flash. Support for Flash ended December 31, 2020."
Where is that Sample folder at? I have 3 folders: Defualt, my name and Public. That's all that's showing.
Thread: Outlines I didn't ask for | Forum: Poser Technical
Thread: V4's J-suit | Forum: Poser 12
I've looked at a cloth from 3d-Age, and I've remarked that if you uncheck "Animated" on the Body's parameter, you may change your character's breasts shape without influencing the corresponding part of the cloth.
My problem's always the opposite- getting the outfit to fit the figure. There have been times, when half the dials won't work- they're there, taking up the screen. But they make no difference at all when you try to use them. The jumpsuit was a case in point. If I clicked on the breast area and tried to use the dials- especially the PBM dials- nothing worked. No matter which dial I tried, none of them made any difference. I'd have to go back to the Body screen to get any dials that actually affected anything.
I've been working with Photoshop almost as long as I've been using Poser- for graphic novels and such. So I'm used to blending 2 or 3 or more renders into one picture.I'm intrigued to see that no one has mentioned the Morphing Tool, which is my go-to solution in those kinds of situations, although if you're that adept with Photoshop, it maybe doesn't matter.
