Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
My copy pf P12 is working fine. I wanted a copy of P10 because it was the last copy to have Wardrobe Wizard in it. The idiots that took it of 11 and 12 have yet to get off their backsides and come up with a replacement for it.I can't help you there but I or others might be able to help you getting yours working again. Or you could upgrade to 11 for $52.
ghostship2 posted at 8:45 PM Tue, 29 November 2022 - #4450622That would be the fitting room. See this post on how to use it.My copy pf P12 is working fine. I wanted a copy of P10 because it was the last copy to have Wardrobe Wizard in it. The idiots that took it of 11 and 12 have yet to get off their backsides and come up with a replacement for it.I can't help you there but I or others might be able to help you getting yours working again. Or you could upgrade to 11 for $52.
Here are some samples of Wardrobe Wizard vs the fitting room. The sweater was one for Vicky 4 and I converted it for Roxie. The first is with the sweater loaded without any adjustments, just conformed.
Here I used copy joint zones on the WW one so it fits a little better.
And here is a wireframe view
mdbruffy posted at 10:28 PM Tue, 29 November 2022 - #4450625Okay. Thanks.ghostship2 posted at 8:45 PM Tue, 29 November 2022 - #4450622That would be the fitting room. See this post on how to use it.My copy pf P12 is working fine. I wanted a copy of P10 because it was the last copy to have Wardrobe Wizard in it. The idiots that took it of 11 and 12 have yet to get off their backsides and come up with a replacement for it.I can't help you there but I or others might be able to help you getting yours working again. Or you could upgrade to 11 for $52.
Can it be saved and reused- re posed? or do I have to go through this every time I want to use that particular item?
RedPhantom posted at 3:05 PM Wed, 30 November 2022 - #4450663
It's a conformer so yes, it can be reposed. You save it to your library just like you would any other clothing. I chose that shirt and figure because I'm going to need a sweater for her.OKay. I do thank you and everyone else. But I've found what I need.
Thanks again.
Anyone know where I can find a copy of Poser 10? I'm willing to pay for it.
