4 threads found!
mimimimi | 4 | 266 | ||
mimimimi | 10 | 755 | ||
mimimimi | 3 | 206 | ||
mimimimi | 1 | 70 |
8 comments found!
There is two tic boxes: Single v Double vv The last ads a caracter/prop The first Replaces BR MIMIMIMI
Thread: Why is my hair comming out in Chess patern | Forum: Poser - OFFICIAL
Thread: The strangest render I have seen! | Forum: Poser - OFFICIAL
Thread: Yes, another newbie looking for help | Forum: Poser - OFFICIAL
I forgot to say: I suggest, Poser 5 nothing less. I have solved the problems I had on stability of that program. Anyhow, a PC user knows to safe often, rather than to be sorry. Michael
Hi there John We all have to start some where at some time. There is a "jungle" of good 3D programs available on the market. You have posted your request for advice in the Poser area so I must assume you already have made your choise.? :-) Well if so, you have made a good choise to my oppinion!! For years I have tried several programs and Poser is by far the most user friendly. If you chose a program like MAX your CPU and RAM will be crying all the way to the bank$. MAX is also a good program but asks the owner to purchase a specific grafic power machine. Poser demands power of your PC as well but is mostly acceptable. Aditional software: Poser is the most used program and therefore it have the largest forum. You can find "freebees" allover the net.... and they are free! You may reply me on request for additional support
Thread: CANT OPEN POSER | Forum: Poser - OFFICIAL
Sorry but the fastest will be Uninstall/ reinstall. Note: This takes less than 15 minutes on an average machine. When uninstalling you do not loose your libary! When reinstalling chose custom setup and deselect the libary installation. It is faster and there will not be made modifications to your setup. Hint: as soon as you start up your poser first time push the the middle UI memory dot. If the preview window after a bad shut down has disapered then just push that dot again. Best luck
Thread: REALLY simple qstn. | Forum: Poser - OFFICIAL
