10 threads found!
nirsul | 0 | 5 |
(none)
nirsul | 1 | 6 | ||
nirsul | 4 | 21 | ||
nirsul | 2 | 5 | ||
nirsul | 5 | 7 | ||
nirsul | 9 | 11 | ||
nirsul | 17 | 99 | ||
nirsul | 5 | 6 | ||
nirsul | 5 | 18 | ||
nirsul | 1 | 3 |
16 comments found!
I use Vue 4.10.02 and a Radeon 8500 card and it is OK with me, I move an object in a view - the others follow.
Thread: pdf manual | Forum: Vue
Vue is better (and cheaper ) but it is a RAMvor (like Carnivor) it eats your RAM out ! and leaves nothing ! When I render something it Vue - I take a LONG coffee break The trees are better but there are less - although you can create easily new plants by using bitmaps
Thread: a graphic card for VUE4 ? | Forum: Vue
Now that E-on have fixed the problem with OpenGL and TNT cards - I may suggest you buy one of the TNT2 or GeForce 2 or 3 cards Nir
Thread: New Pict. | Forum: Vue
Thread: Hello friends :) Link to the beginnings of my Vue site... | Forum: Vue
I hope your mother gets well very soon. - Be strong for her and we are here waiting for you to return to your routine Vue activity now I am going to your webpage... :-) Nir
Thread: Poplar Lombardi anybody ? | Forum: Vue
Guitta ! My intent was NOT getting one that someone bought - but created ! (or made in 3D) please read my first thread carefully ! Nir
Thread: How to make a lake in Vue4 | Forum: Vue
Thread: New Vue d'Esprit images page | Forum: Vue
Is that water running down that path? (the pic in column C, row 5) How'd you do that? It was meant to be a road - what I did is make a copy of the terrain, that change the altitude to 0 in all areas but the one where the road should be - then I made a boolean subtraction resulting in a long riverlike void - I then took a copy of the road and lowered it a bit so that it has "river banks" or "road banks" Nir Nir
Thread: Losing things......??? | Forum: Vue
I have an nVidia TNT2 and OpenGL fails in this application only - It causes problems - slows down and I am unable to select objects etc., But in other apps - this is not happening - so my conclusion is that Vue4 should be fixed - I tested it on an ATI card with much less memory and it worked just fine ! Nir
Thread: Bug in screen refresh (vue 4.10-02) ! | Forum: Vue
