135 threads found!
ominousplay | 5 | 232 | ||
ominousplay | 11 | 419 | ||
ominousplay | 19 | 858 | ||
ominousplay | 9 | 469 | ||
ominousplay | 9 | 346 | ||
ominousplay | 12 | 367 | ||
ominousplay | 15 | 323 | ||
ominousplay | 13 | 457 | ||
ominousplay | 8 | 406 | ||
ominousplay | 6 | 103 | ||
ominousplay | 12 | 151 | ||
ominousplay | 1 | 137 | ||
ominousplay | 12 | 214 | ||
ominousplay | 12 | 316 | ||
ominousplay | 19 | 449 |
663 comments found!
I've started playing with Opentoonz. It contains some powerful 2d manipulation features.
Never Give Up!
Thread: Question about using Carrara for 2D animation | Forum: Carrara
Good advice. Thank you. At the moment, this is a hobby. I like to see what I can do with what I have... and I get ideas and want to see them realized. I like being back in this forum.
Never Give Up!
Very nice. I think I'm on to something with a flat vertex object, rigging it with bones. I'm trying to load the image I want to trace (the sprite) - something I draw in Procreate and save it as a png with a transparent background. I want to map it to the flat vertex object. I'm having trouble with Carrara. It keeps crashing when I try and adjust the mesh - weight mapping. Every time I touch the bone to increase its influence, Carrara crashes. Ugh! I like your method. I am hoping to come away from Carrara with animated gifs similar to what can be done with Creature Pro - lots of mesh manipulation on a sprite to show dynamic movement. Thanks Mark! Any idea why Carrara Pro 8.5.1 is crashing in the vertex room when adjusting weight mapping?
Never Give Up!
Thread: New Gallery Upload | Forum: Carrara
Here is a Carrara capture. I'm playing with Unity and wanted to see if I could bring in my own 2D sprites created and animated in Carrara.
Never Give Up!
I have not added anything in some time. This is a quick colorful bird that I'm animating on small planes. Maybe the .gif will show up.! Nope. The .gif was animated from .png images, but it looks frozen with a black background instead of transparent. Anyway - I'm animating it by spinning the planes on their hot points. Next I will try bones.
Never Give Up!
Thread: So long, and thanks for all the fish... | Forum: Carrara
Sorry to see you go, but glad you are not leaving the community. Thanks for all your help over the years.!
Never Give Up!
Thread: vertex modeling room not refreshing quickly | Forum: Carrara
Ok, I want for the upgrade to 8.5pro, but I can't seem to get a runtime from C7Pro into 8.5. It installs, but no images, seems like it reads the content, but no images at all show up. Any ideas?
Never Give Up!
Thanks Kixum. I wasn't looking at it right. Open GL still isn't working in the vertex room, but I dragged in a high-vertex object and even in software mode in the vertex room, it refreshes good enough to use.
Never Give Up!
Um... seems to be fine now. I switched it to Software, and it worked better. Went back in and it was on OpenGL and it refreshes in the vertex room like a champ so I don't know what happened. Anyway - I'm not messing with it now. Thanks for the help.
Never Give Up!
Ok, I'm answering my own questions here. I can't increase the vRam. Should be enough for Carrara anyway. Maybe something else is going on. I could save my Runtime out and do a fresh install of Carrara 7Pro.
Never Give Up!
Graphics: ATI Radeon HD 4850 : VRAM 512 MB -
Seems like I've increased VRAM in the past... can it still be done on newer iMacs?
Never Give Up!
Ok. OpenGL is the graphics hardware accelerator... My iMac: 2.66 GHz Intel Core i5 4 GB 1067 MHz DDR3 memory Version 10.7.5 (afraid to upgrade with all my old software) Carrara 7Pro
Never Give Up!
Thank you! I switched to Software and now it refreshes instantly with a simple cube. My settings were just like your settings for OpenGL and nothing was changing. Maybe my OpenGL is broken? Can it be broken? I'm kinda joking because I don't know why it is not working with OpenGL...
Never Give Up!
Thread: All hail John Berkey | Forum: Carrara
