2 threads found!
orodreth | 3 | 44 | ||
orodreth | 2 | 67 |
5 comments found!
You are entirely correct.
IÂ based my case on observation only and not on the actual models.
My apologies. Better to think and investigate before making claims.
Thread: What a car | Forum: Poser - OFFICIAL
ruh-roh...
hankster
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=25516
pretty3D
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=77704
Looking at the product numbers, IÂ say someone copied someone.Â
But it's also entirely possible they both got the car from another source.
discuss
Thread: Newbie: Parameter dials *stop* working: Why?? | Forum: Poser - OFFICIAL
I've had this problem before in Poser 6. By trying to repeat the problem I've found the following two reasons for parameter "lock"
Sometimes my morphs revert to zero immediately after I save a file and the "save as..." dialogue box disappears. Pose and Camera and Lights are not affected, only the morph dials on the body and head of my figure. This doesn't happen often and I'm not sure why this occurs but I found that I can just close the current file and then open the version I just saved and everything is fine (the correct morphs were saved).
Secondly, I've had parameters lock after adding and deleting a lot of other figures in the scene. Say for example I bring up a figure and add morphs and then add a character set... then add and delete a bunch of clothes and hair figures and props (tests for myself or the client)... When I go back to make edits to the figure body and head dials, they are all stuck with the current morphs and don't change. I can change rotations and bends for body parts, but body part morph dials no longer work. The only way I've been able to get over this is to go back to a previous save and redo the lost work.
I just got Poser 7, so maybe these bugs will be fixed.
Thread: barcode looking texture map on prop... | Forum: Poser Technical
Thanks for the article, thats exactly whats happening. I'll try adding the node and see if that fixes it. ~Orodreth
Thread: Poser5 SR3 depth map shadows disappeared | Forum: Poser - OFFICIAL
I installed SR4.1 tonight and loaded some new lights and primitives and the Depth Map Shadows have returned. Opened one of my old shadow test files (where the depth map shaodws first disappeared) and rendered it, and the Depth Map Shadows worked! Turns out, when I was doing my update I noticed that I had SR4 already, so this problem WAS the DM shadow issue people were having trouble with. SR4.1 with shadows... opens faster... renders faster... live is good again!
