2 threads found!
philadam | 11 | 747 | ||
philadam | 2 | 56 |
16 comments found!
Doesn't work in Poser 13 either, so I have filed a support ticket and they agreed that it doesn't work.
Thread: Library Search | Forum: Poser 12
Just downloaded Poser 13 trial and it does the same thing. In Poser 11 Library list acted the same as any windows list or file explorer. At the folder level typing the first letter of a folder name would take you to that folder. After expanding the folder, if the list was long typing the first letter again would take to that list item. So it wouldn't make any difference whether you were at the folder level or item level, typing the first letter would speed up the list search.
If I open a folder it works, but not at the folder level. In poser 11 it works at all levels, the same as windows file folders work.
Thread: Want to re-test Poser12 | Forum: Poser 12
I'm not that familiar with Mac's, but you could try and set up a virtual machine and create a sand box to play in. I do with windows 10 all the time.
Thread: Project Evolution ONE now available here | Forum: Poser - OFFICIAL
Thread: Poser 12 Cycles preview | Forum: Poser 12
DustRider posted at 2:06PM Wed, 04 November 2020 - #4403281
philadam posted at 12:45PM Wed, 04 November 2020 - #4403121
DustRider posted at 2:30PM Tue, 03 November 2020 - #4403092
Not My Image!!
That's my image, but I have no idea how it got included with your's. Started to post as an example of firefly, but it was late so I canceled the post. It's great to know who it belongs to! Was it done with P11 or P12? Well done, and IMHO better than the early promos!
It is P11. I still prefer firefly, because I can get excellent renders in fraction of the time that superfly takes. I am an impatient person, so I don't like the wait.
That's weird!! My post with the mages above is now showing and image not done by me (the first image), and has a corrupt reference to my second image. However the gallery links are still working properly. I first noticed it yesterday that the links were not working on the first two images. Now somehow the first image link is working, but it's not MY image. I don't want to spam the tread with repeat images, but I don't want someone to think I'm claiming their work!!
So, to make things clear I'll re-post the first two images from my post above again (sorry for the double post should the images magically re-appear above. I did a quick inspection of the post, and the actual links are bad so it doesn't seem to be just a server glitch, even though they were functional when they were first posted). Note: These are examples of the minimum quality images I feel should be used for promotion of Poser 12, see my post/discussion above (on Page 2) for clarity.
This image showing in my post above is not my image, I don't know who it belongs to (even tried doing a reverse image search so I could let them know), and I didn't post it (but I am reposting it here in case things get even weirder to make sure it's clear I'm not trying to use or claim anyone else's work). Nice image though, kudos to who ever did it!
Not My Image!!
Thread: SM Poser Forum Kapoof | Forum: Poser - OFFICIAL
Can't believe Rendo didn't make arrangements with SM to preserve that info. Years of valuable information down the tubes, just like when daz3d dissolved RuntimeDNA.
Thread: GeForce GTX 1660 - Yes or No? | Forum: Poser - OFFICIAL
FYI: Did some tests and apparently the scene I was trying to render in SF took up to much GPU memory. Even though the scene is only 200 MB I would keep getting a "Out of device or host mapped memory". Error would flash by so fast I didn't see it. Sadly no errors in poser log files or system error logs to indicate there was a problem. So after a little research this appears to be a GPU error. So I guess 6 GB of video memory isn't large enough for a GPU render of my scene.
I went back to 11.2 because I got tired of 11.3 crashing on me all the time, so maybe that's why superfly doesn't work for me. Hope they get all of these issues resolved soon.
Thread: Wet skin in Superfly? | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
I still use Firefly a lot. Is there anyway to get the FF legacy Nodes compound node expanded?
Thread: Network Drive Trouble | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Make sure you are using a drive letter (r:) and not a UNC (like \server\content\Runtime). You can use the command prompt "net use" to verify.
Thread: Poser Shader Thread List Revived | Forum: Poser - OFFICIAL
Thread: Superfly with GPU rendering on GeForce GTX 960 | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Take a look here: https://forum.smithmicro.com/topic/3854/cuda-error-at-cuctxcreate-launch-failed/6
