7 threads found!
pixelsquash | 3 | 325 | ||
pixelsquash | 7 | 305 | ||
pixelsquash | 2 | 153 | ||
pixelsquash | 6 | 115 | ||
pixelsquash | 11 | 270 | ||
pixelsquash | 2 | 26 | ||
pixelsquash | 7 | 227 |
24 comments found!
Thread: Poser7 cannot find my textures in custom Runtime folder | Forum: Poser - OFFICIAL
Thanks a lot you both! That was indeed he problem! The Poser library structure is pretty confusing anyway. ;)
www.renderosity.com/mod/gallery/browse.php
Thanks Dizzi. I checked the LibraryPrefs.xml file but everything seems to be ok in there though ... The line for my custom Runtime looks like this ...
<ContentFolder folder="C:Documents And SettingsmynameMy DocumentsE FrontierPoserUser RuntimesPixelsquashLibraries"Â index="2" >
I have some references to textures in the default Runtime AND to textures in my custom Runtime in the material files. Is that ok? Otherwise I have no clue what is wrong. The path names all seem to be correct.
Hmm file search is set to depth by default so that's not the problem. Any other hints? Are textures only allowed in the default runtime?
Thread: Poser book question:::: Which or either? | Forum: Poser - OFFICIAL
Just received Practical Poser 7 and worked through the first couple of chapters ... a great book really, especially if you are not too deep with 3D in general but you don't need to get an explanation of every single menu item (I think that is what Poser 7 Revealed is for).
Thread: Windows Vista and Poser | Forum: Poser - OFFICIAL
Quote - pixelsquash -Â The distance your pointer moves across your screen, vs. how far you've actually moved your mouse, is a windows setting; called something like Mouse Speed.
Not sure about the middle button though. :Â (
Yes I know that. But when you set Mouseware to fastest and then set the Win generic driver to fastest, the Logitech driver is still alot faster (and more precise) than the Win driver. I.e. the win driver simply doesn't offer the same acceleration scale.
Thread: What celebrity is her? | Forum: Poser - OFFICIAL
Quote - IVideo marketing is all the rage so Daz are just following the latest trend by using YouTube.
... btw not a very professional step to choose YouTube for advertising! YT is unmoderated and anyone can post their troll comments there. Really sometimes spoils the videos that are up there!
Before deciding to use Vista get yourself aquainted to the annoying protection mechanisms that simmer under it's hood ... http://www.cs.auckland.ac.nz/~pgut001/pubs/vista_cost.html
Also if you use a Logitech Mouse that uses Mouseware and your plan to keep it like that, note that Logitech doesn't plan to develop any Vista-compatible drivers. My MX310 runs with the Vista generic Mouse driver but its a lot sower than with MouseWare (higher DPI?) and middle mouse button doesn't work! The driver situation for Vista is a horror (because of the aforementioned protections).
Thread: Member passed away | Forum: Poser - OFFICIAL
It's sad to see somebody in the best age to leave us all behind! I know it from own experience because I lost a good friend about a year ago. You have my deepest condolences!
Thread: Poser crashing on startup? | Forum: Poser - OFFICIAL
nruddock & pjz99 thanks for the explanation! So after all the situation seems not so bad. I just wish I had known that yesterday! ;)
Thanks but could you enlighten me a bit? What are binary morph targets used for? I'm not really that far with Poser.
thanks nruddock! That worked but as expected all my face morphs are lost. So I have to start over because this file was pretty much only a custom face. My question before I start again would be: Does this V4-Poser incompability mean that I cannot use custom morphs on V4 at all or are only certain morphs affected by this?
Does it work for you PerfectN? I saved a V4 scene yesterday and today I experience I cannot open it. Crashes to desktop everytime. also unchecking Use external binary morph targets does not help.
Any info when V4 will work correctly with Poser 7?
Thread: Good Poser book? | Forum: Poser - OFFICIAL
Thanks Marque! I will probably go for that one. Secrets of Poser Experts also doesn't seem to be a bad choice. **Poser 7 Revealed looks more like it is a beginners guide.
Thread: Just bought Vue 6 Revealed... | Forum: Vue
Makes me wonder: Vue is highly popular and soo complex that libraries could be filled with topics about it. But searching on Amazon I cannot find a single book about it except the one mentioned here which seems to be pants. Compare the book situation with Maya, Max or even Poser!
Thread: Whats this hair style? | Forum: Poser - OFFICIAL
