11 threads found!
pixpax | 10 | 714 | ||
Advisories: nudity
pixpax | 7 | 439 | |
pixpax | 4 | 866 | ||
pixpax | 6 | 191 | ||
pixpax | 2 | 97 | ||
pixpax | 5 | 73 | ||
pixpax | 0 | 15 |
(none)
pixpax | 16 | 338 | ||
pixpax | 8 | 193 | ||
pixpax | 6 | 116 | ||
pixpax | 7 | 171 |
120 comments found!
Thread: Looks Like I am going to have to give up on Poser 13 | Forum: Poser 13
I had the exact same problem with F-Secure. I switched to Norton and everything works because I was given the opportunity to allow the dll.
Hope you get it all to work.
Thread: Best way to create a UV map | Forum: Poser - OFFICIAL
Hi there
What options have you tried in UV-mapper? As far as I remember the "Box" option could perhaps work for what you want to do.
Thread: Poser - or not? | Forum: MarketPlace Customers
Rhia474: I have also noticed what you mention about the sponsored links! Not much poser there.
And yes, there is the new Poser in red in the top corner. I thought that was great but there is not much in there and it was not the option to bbrowse only Poser-stuff as I hoped.
Happy new year to all of you out there :-)
Thread: Problem posing a resized figure | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Thanks for answering! Here is the longer explanation
I am using La Femme Pro - tried it on La Femme 1R1 too with same results.
I used Deecey´s Bodykit morphs, the standard morphs that comes with the figure and some custom morphing in the face area.
The face/body chips are misplaced too - they stay where they are on the standard La Femme.
I have saved the morphs in a cr2 - and think that the problem is not in the morphed figure - she behaves normally. See:
I have used Spawn Morph Target and then exported as INJ.
As long as the morph is just spawned in the figure it works. When I Inject this happens:
It could probably work with the obj-export/import but I really want to have the bodykit morphs for when making clothing fit, that would be a lot easier than having to morph clothing from scratch.
I tried the Match Centers to Morph- suggestion on this one - and it worked! But how can I tell the inj to do that?
Thanks for your time!
Thread: Principled BSDF - some examples | Forum: Poser 12
Thread: Poser Staff Picks Oct 5 thru Oct 11 | Forum: Poser - OFFICIAL
Thread: Free light set for Poser 11 | Forum: Poser - OFFICIAL
Thread: Texture lines in Firefly - not in Superfly | Forum: Poser - OFFICIAL
Thank you SO much. Lowering the shading rate helped quite a bit. At 0,11 the lines are completely gone! And I could put the filtering back to crisp without messing things up! :-).
HI
Thanks for helping me out. I actually remembered having the problem when you mentioned it :) But not how it was solved though.
Thread: Saving Master dependencies - how? | Forum: Poser - OFFICIAL
Thanks for taking time to read this.: Here is some more info: I have made sittingposes and clothes. Posing the figure causes problems with the skirt and/or long shirt/vest and I have made morphs that fit the poses or morphs that makes the clothing look more natural in the poses. Instead of going through the clothing items one by one and changing the settings to fit the pose I want this to be controlled by a Master.
I thought it was simple enough to make the master in the girl, set the dependencies and then save as an inj-file. :-) Couldn´t do that......tried saving the Master in one of the clothing items - but as described above, it only saves the info for the item it is in - not the other clothing item. (Saving a master in the girl saves nothing but the name of the master dial.)
I have tried to save as inj-file. I have tried saving a CR2 and copying the master - but there is no vital information in the file.It saves as an ordinary pose-file. So tried saving as a pz2. Same result.
I can set up the Master and it works fine on so far three items at once. But it is no good if I can´t save it. So here´s hoping somebody can solve this mystery. I MUST be doing something very wrong. But what? ?
Thread: Poser Staff PIcks: Jan 1 - 8 | Forum: Poser - OFFICIAL
Thread: Back after a long hiatus | Forum: Poser 13
