1 threads found!
rbjensen | 6 | 271 |
5 comments found!
If you get UVMapper Pro, you can preview your texture on the object as you work in the paint program. BJ
Thread: what do you think about Digital Carvers plugins | Forum: Carrara
I just got Anything Grooves and Anything Grows. Although I would not call them intuitive to use (it seems very little is in 3d software), after going through the tutorials, I was able to get good results. Unfortunately, since Carrara is made up of many different plug-ins, there often is not consistency in how things work. You may need to adjust your mindset a bit and not try to use these plugins as you might other parts of Carrara. So far these seem to work as advertised and work well. BJ
Thread: Lighthouse WIP | Forum: Carrara
This is gorgeous! As with Kix, it is just the water that looks odd. Would love to see it rendered with GI.
Thread: Caligari TrueSpace | Forum: Carrara
Thanks for the replies. As for the texturing issue that EricofSD brings up, I think TS has a brush tool for painting directly onto the model. C2 does not -- it just has the polygon layers that you can put on the model. I doubt the TS brush tool is as powerful as deep paint, though. I do think that the C2 shader trees are quite powerful and easy to use, though often hard to grasp all that can be done. I have to agree with some of the responses. TS offers lots of capabilities, and for the price, seems to offer more than C2, but I have not gotten used to the TS interface. It looks nice, but I have a hard time getting used to it. I like the properties tray in C, where you can see all the numbers. I often manipulate objects by typing in rotations, coordinates, and dimensions. In TS, I did not see how to keep this stuff easily accessible. Also the C modeling rooms make it easy to model with exact coordinate values and dimensions. I also like the easy hierarchical access to everything in the sequencer tray and with shaders. Perhaps I have gotten too used to the C interface and hesitate to give it up for something that may be better. I think TS 5.2 is a great deal at $300 (cross grade) or $400, and it feels like a more professional tool (though it still seems to be a niche tool compared to LightWave, Cinema4D, 3DMax, etc). The images in the Caligari gallery are beautiful, which speaks to the tool and the artists that use it.
Thread: Tutorial / helpful hints on importing Poser character to C2? | Forum: Carrara
I am not an expert, but I was playing around with this myself. I exported from Poser and set the option for grouped objects. When the model came into C2, I could expand in the sequencer tray and see the different parts of the model. In my case, the hair was named "neck". I selected "neck", went to the Shader room and the color texture was properly applied. I was able to add the transmap and get good results. I had a similar issue with the eyes. The eyes imported without texture, but I was able to select each eye, go to the Shader room and apply an eye texture map. As for eyelashes, the eyelashes were part of the head. I selected the head, went to the Shader room and applied the eyelashes transmap, but unfortunately, this didn't work. I am not sure why. These are my experiences -- if there is a tutorial or better methodology, I would be glad to see it.
Thread: tutorials for uv and carrara? | Forum: Carrara
