15 threads found!
reddog | 3 | 73 | ||
reddog | 2 | 69 | ||
reddog | 0 | 14 |
(none)
reddog | 10 | 218 | ||
reddog | 1 | 74 | ||
reddog | 2 | 19 | ||
reddog | 2 | 13 | ||
reddog | 0 | 6 |
(none)
reddog | 0 | 7 |
(none)
reddog | 4 | 22 | ||
reddog | 5 | 28 | ||
reddog | 7 | 51 |
2001 Jan 20 11:31 PM
reddog | 4 | 17 | ||
reddog | 0 | 5 |
(none)
reddog | 0 | 7 |
(none)
69 comments found!
the inability to directly export .obj .3ds is one thing about Bryce that puts me off. but it can be done, open the object (hilight it)with the list to the right hit the E so that you are bringing up the smoothing tool but at this point do a Ctrl-D and this will bring up export dialog box pick the format and where to send it just like other programs from there on. now you havethe model to use in another program.
Thread: Plate armor sets WIP | Forum: Poser - OFFICIAL
see XURGE's sit or link or whatever he has available as far as tuterals. i watched him make a armor vest at dragon*con while giving a speach on how Rhino workes in about 20 min. of course he gives classes for Rhino in Miami. keep heiarchy matched to Poser parts is all i can say. the d/c demo class might be available from here by now.
Thread: Informal survey - OS? | Forum: Poser - OFFICIAL
Thread: Colouring tiled obj surface? | Forum: Poser - OFFICIAL
try pulling it into poser. select the groupping tool, squaire with the dot in the centre (center). pick NEW GROUP name it then click on parts of model to add them to the group. ctrl click subtracts them from group. about thr same thing can also be done in true space and rhino only it is lots harder and you need plugins in truespace. save regrouped model and apply new textures. plan it out and you can have differant patterns by what groups you pick
Thread: destroyed uv map of bikini top and bottom (need help) | Forum: Poser - OFFICIAL
remember if you start having troubble .rsr file is the one to get rid of. poser looks for it to use but it also makes a new one. if .rsr file is larger than .crc file then the rsr most likely is bad. i often go to the objects folders and erase all .rsr there. also keep a good copy of the main poser.rsr , .crc , .exe files in a safety folder to coppy back to the main Poser folder if anything goes wrong so you won't have to reload poser
Thread: OBP to OBJ converter? | Forum: Poser - OFFICIAL
did it years ago. short is to group items, goto the "E",{like to smothe the selected item} do a ctrl (D), pick format needed, there is .obj , or .3ds . read bryce F.A.Q. at top of bryce forum it tells in detale.
Thread: long long time ago | Forum: Photoshop
the Uled/Aldus photostyler is the main root where the standard for photo processing came from and it eas way ahead of the croud in its day. adobi dropped many features when they started marking photoshop.the copy i had was 16/32 bit program origanly for a mac ported to 3.1windows. (dreamer101)the link to photoimpact is inop.
Thread: Where can i get detailed CR2 help? | Forum: Poser - OFFICIAL
if your sending to this site then you probably have the first tool to get into any filr and microsoft gave it to you. it is a litel thing called edit.com in your dos folder.and you will start to learn what is in a .cr2, or .rsr or px3 file. it is the base look see program of them all.the other things, go to the utility section in free stuff or equiv depending the site and grab what you need. thats what its there for. if your in a third world countrey then go see the consulat and bug them for a while and you might get one (a program) that is better than buy.
Thread: Anybody else having a problem with slowness in the galleries? | Forum: Poser - OFFICIAL
never got great speed. used to keek page size to 24+ and that did help loads but now it is caped at 18 and it makes it even slower.
Thread: WIP Jurassic Meta Lagoon | Forum: Bryce
Thread: Peej's texture is cool. Orange on Blue background Radiosity Full on! | Forum: Bryce
Thread: Skip dragging instead of smooth dragging | Forum: Bryce
don't be afraid to take the ball out and clean the rollers often. dirt raps arround the rollers quickly, especialy when pop and other drinks are spilled in the area.
Thread: Bryce 6 suggestion-list. Please everyone, tell your wishes for Bryce 6 here! | Forum: Bryce
i was wondering if there was a hard copy users manual. the pack i got was boxed for a book but it wasn't there. of course the price was about half what others want for it.yes it did come threw a greymarket seller
Thread: Error Message while importing object in Bryce 5 | Forum: Bryce
by this point i useually get a crash when 5 looks for mtl or jpg so to hell with the hastle, i load it in 4, obp it and send it back to 5
Thread: How not to distribute free stuff | Forum: Bryce
Thread: One thing I never could figure out about Bryce 5.... | Forum: Bryce
