Sat, Nov 30, 9:37 PM CST
Subject: destroyed uv map of bikini top and bottom (need help)
Leyla ( ) posted Wed, 17 July 2002 at 8:56 AM ยท edited Sat, 30 November 2024 at 8:05 PM
hi guys, somehow i detstroyed the uv maps of victorias bikini top and bottom :( i dont know how this could happen (though i downloaded and installed a lot) i replaced the obj files with the originals but this didnt help. (in poser it only shows with the mesh collor and in 3dmax it says that it has NO UVMAP!!!?!?) i dont want to reinstall poser and all stuff because my "runtime" folder has more than 1.5 gig and that would be sooo much work. does anyone have an idea how i can fix this? can i get (and reapply) the uv map somewhere (from daz or anyone here)? thanks for trying to help leyla
c1rcle ( ) posted Wed, 17 July 2002 at 10:05 AM
replace the originals again but get rid of the rsr file that's in the folder with them, poser still thinks it's using the damaged ones. Rob
Leyla ( ) posted Wed, 17 July 2002 at 10:10 AM
hehehe, i just installed the update (i didnt do before and i never used textures on the top and bottom) the skirt seemed to has no map too thanks anyway circle! ;) leyla
reddog ( ) posted Wed, 17 July 2002 at 10:08 PM
remember if you start having troubble .rsr file is the one to get rid of. poser looks for it to use but it also makes a new one. if .rsr file is larger than .crc file then the rsr most likely is bad. i often go to the objects folders and erase all .rsr there. also keep a good copy of the main poser.rsr , .crc , .exe files in a safety folder to coppy back to the main Poser folder if anything goes wrong so you won't have to reload poser
