8 threads found!
rubidium | 14 | 655 | ||
rubidium | 79 | 1871 | |
rubidium | 8 | 170 | ||
rubidium | 5 | 140 | ||
rubidium | 9 | 191 | ||
rubidium | 19 | 574 | ||
rubidium | 14 | 434 | ||
rubidium | 18 | 262 |
40 comments found!
Hello, I have recently bought the product (Black Friday Sale ) and I am trying to learn to use it. I am having difficulties trying to apply some materials: in some cases, when I drag the material to Genesis 3 male (in the instances tree) I get the following error: Error: node name://%40selection/Genesis3Male: not found It happens only in some cases; with other genesis 3 characters the materials can be applied without problems. i suppose that I amb doing something wrong but I do not know how to solve it... Could you help me with this problem? Thank you in advance! Ramon
Thread: The Future Of Carrara? | Forum: Carrara
3doutlaw posted at 3:13PM Tue, 08 March 2016 - #4259848
It would be interesting if they tried a different approach, such as the selling of a required proprietary part of Carrara, and making the rest open-source. In this way they could make the source code public, and folks can contribute, but they would maintain a core required piece that they could sell. That way the public could contribute, and they could maintain a product.
Poser has a SDK available. I think that it should be possible to build enhancements to the software as an open source collaborative effort...
Thread: A Review Of CPU Based Rendering Solutions For Carrara... | Forum: Carrara
You can search for Octane in the gallery, here at Renderosity, in order to get a glimpse of the capabilities of this renderer.
Â
Ramon
Thread: Two versions of Bryce 7 | Forum: Bryce
Thread: exporting booleans | Forum: Bryce
 Hello
I think that I have read somewhere (perhaps in the DAZ forums?) that Bryce 6.3 had a bug with exporting booleans.
Ramon
Thread: WIP: Virtual reconstruction of the Emporiae Roman Forum | Forum: Bryce
Bobbystahr, thank you for the links; IÂ have assigned more virtual memory to WIndows, and in fact my disk is badly fragmneted... I will try to save the file after defragmenting it.
Pakled, I am building the scene in small sections (the temple, the temple basement, etc) and then I I assemble them in the larger scene... the numbers that I posted are the ones that Bryce gives when I use the "deselect all" option... I would not be able to track the objects individualliy ;-)
Best regards
Ramon
Thread: Happy New Year! | Forum: Bryce
Thread: OT - Happy Christmas | Forum: Bryce
Thread: bryce specific refraction settings | Forum: Bryce
Have you read about the new materials (metamaterials) with a negative refractive index?
en.wikipedia.org/wiki/Metamaterial
These materials could be used to make cloaking devices or superlenses...
Unfortunately, it seems that Bryce does not accept negative values for the refractive index... it would be interesting to see what the renderer would do with these materials :-)
Ramon
Thread: !!!! - ARCHITECTURE - CHALLENGE - VOTE HERE - !!!! | Forum: Bryce
This is the first time that I vote. It has been a difficult decision, due to the great quality of the works .
#8 grafikeer - 3 points
#28 rj001 - 2 points
#20 jrcejaspulido - 1 point
i think that everybody deserves an honorable mention... but I woull like to mention the following:
#15 neighborsgoat
#27 thunderstone
#32 dan whiteside
#35 dbrv6
Greetings
Ramon
Thread: Can i make a terrain with bryce and save it-and then use it within poser? | Forum: Bryce
have you thought about the inverse possibility? That is, import the figures in Bryce and use the Bryce renderer.
Ramon
Thread: O.T. MSN cannot store your important emails on your puter without MSN! | Forum: Bryce
It seems that it is possible to read hotmail or msn mails using outlook express or thunderbird, using free software. I do not know if it is allowed by microsoft.
You can also (as AnnieD says) forward the mails to a free gmail account, that can be read with thunderbird or outlook, and can be stored in your computer.
Best regards
Ramon
Thread: DazStudio 2.2 released with 100 bug fixes. | Forum: Bryce
Thank you for reporting this.
However, some people say in DAZ forums that Bryce does not work with this new version of DS. Have you tried to use the DS/Bryce bridge?
Best regards
Ramon
Thread: Objects that move when changing selection? | Forum: Bryce
Yes, the model has complex grouping... for the moment, locking the objects that moved has worked. I have nearly finished the building, so I hope that the problem does not happen again :-)
Ramon
Thank you for you help. I have been trying to follow your advice, but I could not select the objects in order to lock them because they moved whenever I tried to select them. Also, I could not select the family for the same reason.
Finally I have made the following: I have taken note of the position of the displaced objects using and older version of the file. Then, grouping and ungrouping them I have moved them manually to the desired position, and then I have locked them. It seems that now they do not move anymore ! :-)
Best regards
Ramon
Thread: carrarActor - genesis 3 | Forum: Carrara
