6 threads found!
shadu | 0 | 50 |
(none)
shadu | 2 | 47 | ||
shadu | 4 | 270 | ||
shadu | 3 | 19 | ||
shadu | 5 | 21 | ||
shadu | 5 | 21 |
7 comments found!
Thread: cavern scene | Forum: Vue
I will effectivement need some camera movement in it. The camera will pull away from the central point in direct line until it pass in the wall and exist outside in the forest.
Someone suggest me some image projection... How can i do that in vue? Is there any good tutorial about that?
For the shape this is a idea to madel it somehere else...
I made a new test using a new technic. I used a difference boleen function on 2 terrain to obtain the cavern this time. I think the look is better. I still need some better texture... But i think it is better.
http://www.imaginethisproductions.net/p3/grotte_p3_gen2.jpg
Shadu
Thread: multi-layer and shadow | Forum: Carrara
In vue i can render two image of all my render (even more but make it sample). One is my model without any shadow and the other is the shadow of my model alone. By putting the two together in combustion, AE or photoshop (shadow layer on top with multiply transfert) i can ajust the softness of my shadow and his opacity very quickly and without make a other long render. Is it possible in carrara or did a plugin can permit that? I saw a python script doing that for poser by exemple. Shadu
Thread: Import camera mouvement in vue infinite | Forum: Vue
find it.... YOu cannot tell the number of frame in the plugin. But the plugin take the number of frame from the render windows... you just have to set the number of frame to render than go back in the plugin and reset it. Shadu
I try the plugin on the CD... And i am stuck at 100 frame transfert between max and vue..... grrrrr.... It is normal? shadu
Thread: Light in a glass ball | Forum: Vue
Thanks I didn't find exactly where the problem was. I thing it come form the size of the light source. Part of it is in the wall and make less light like this. I made a pillar with a crystal ball and it work perfectly. Shadu
Thread: Mood Light | Forum: Vue
Thread: Render crash during animation | Forum: Vue
