19 threads found!
solofalcon459 | 3 | 15 | ||
solofalcon459 | 7 | 49 | ||
solofalcon459 | 0 | 4 |
(none)
solofalcon459 | 15 | 625 | ||
solofalcon459 | 2 | 121 | ||
solofalcon459 | 3 | 59 | ||
solofalcon459 | 2 | 111 | ||
solofalcon459 | 13 | 353 | ||
solofalcon459 | 7 | 234 | ||
solofalcon459 | 11 | 193 | ||
solofalcon459 | 2 | 137 | ||
solofalcon459 | 26 | 545 | ||
solofalcon459 | 1 | 232 | ||
solofalcon459 | 7 | 229 | ||
solofalcon459 | 6 | 173 |
36 comments found!
I've been through the modified file 6 times looking for errors and it still only loads the first claw. I'll have to start over and see what I goofed up.
Thread: Saving groups of props together | Forum: Poser - OFFICIAL
Thread: Question @ Blackhearted (or someone who has GND2) | Forum: Poser - OFFICIAL
Some comforming clothing will fit her, you just have to tweak around for a while. I usually get as close as I can and then postwork the clothing to fit better. She is such a departure from the standard V3...I was intrigued and not one bit sorry I got her. If you are able to do some postwork or don't mind tweaking then go for it.
Thread: Transparent Gloss effect on skin help... | Forum: Poser - OFFICIAL
I'm open to suggestions...the method I used with P5 was material room-based but anything that would work is ok with me. In the past, I used the free lilflame zipper catsuit. It was a bump map and color reflect nodes. Somehow, after I applied it and then reapplied the character's skin texture, the bump map (or something) stayed there and looked just like a clear catsuit on top of the skin. It had enough depth to give the illusion of being a layer of latex. Apparently it was an exploit with P5 since P6 won't fall for it. :(
Hmm...Specular makes the texture shiny but theres not an appearance of thickness (sorta like refract but not the whole figure). Catsuits give me the fits since they usually won't conform correctly. That would work though. I'm sure there's something I'm missing... Figure is V3 in P6.
Thread: V3 new generation 2005...any opinions? | Forum: Poser - OFFICIAL
I have not moved to dynamic clothing yet...conforming clothing works for me fine so that might be a problem. I do like to mix and match injections and clothing, combining mats and such to create different effects. It sounds like this new pack is not something I'm ready for quite yet. /dumb question/ Is Morph manager a DAZ product? /dumb question/ THanks for the info!
Thread: Need freaky sci-fi hair | Forum: Poser - OFFICIAL
Thread: adding textures together | Forum: Photoshop
Thread: Help with BAT's Robot Cyber | Forum: Poser - OFFICIAL
Thanks. I finally figured it out. I like cyborgs but there isn't much out there along those lines. Thanks again!
Thread: Morph dials don't work on V3 | Forum: Poser - OFFICIAL
Poser gets weird at times...as was said above, make sure you have the correct figure selected and then "body"... Sometimes I have to actually click on V3 to get the object menu to refresh, otherwise I wind up wrecking something else... solo
Thread: If there was one piece of advise you'd give a new modeler.... | Forum: 3D Modeling
<<Drop by the Wings tutorials here, in the Tutorials section..Draculaz has a good one on basic commands (the spaceship one..don't try the robot until later..;)..I have one on intermediate stuff, and Puzzled Paul and others can handle the advanced work..don't feel bad..first time I downloaded Wings..I couldn't even generate a primitive..had to go to the Wings forum and ask..;)>> I'm digging my way through the menus...I already got frustrated as I could not figure out how to change the view or zoom! Arrgh! It's getting better slowly. I've been to the tuts but it took me a hour to find the "move" command!!!
My two cents... "save"! :o) M <<< You got that right! Lord knows how many renders in Poser I've screwed up and lost because I didn't save three hours of work then it crashed... Ouch! solo
