12 threads found!
spider1313 | 43 | 1809 | ||
spider1313 | 2 | 71 | ||
spider1313 | 17 | 329 | ||
spider1313 | 3 | 161 | ||
spider1313 | 3 | 24 | ||
spider1313 | 15 | 369 | ||
spider1313 | 11 | 256 | ||
spider1313 | 4 | 97 | ||
spider1313 | 8 | 146 | ||
spider1313 | 10 | 243 | ||
spider1313 | 3 | 134 | ||
spider1313 | 9 | 197 |
147 comments found!
Just realized upon returning here that Poser doesn't really have a store 8*)...but what I meant was I do have most everything from DAZ and RDNA (pre--cutie/G2 days) so I could help you out there.
I did import Transponds' Western Church from RDNA and tried to export it....maps checked...and VUE6F locked up on me. Checking in 5I now...
Worked like a charm in 5I...in less than two minutes I imported the same item, saved it out as a .3ds and had it reloaded!
This is working with POSER 6...
Steve
Thread: Export Problems | Forum: Vue
WOW! Something else a bit off with our new and improved VUE6F?
Sarcasm aside...@ iloco...what exactly are you trying to export to .vob? If it's a Poser import, since I own most of their store...geeee, wouldn't a nice 60' Plasma TV look better here in my playroom?...LOL...I could try and replicate it for you?
Steve
Thread: Problem over at e-on and Cornucopia | Forum: Vue
shaking head here
Just got here from the e-on forums where sbell is posting "Test" replies to the few threads visible (some of them dated 2004)...LOL
If it's not one thing, it's another of late with them, isn't it?
If I didn't love the "working" versions of VUE I have had I would just walk away from it all...
Steve
Thread: Totally confused(not to mention disgusted)over the "Final Release"!!! | Forum: Vue
Ok now! Done with that book and ready to get rolling with 6F...but alas I see no action yet from e-on, other than the fact that their forums have been almost completely obiliterated...hmmmm? can you say coincidence?...LOL..so I guess I will just grab another book and check back in in a few days or so...8*)...
Steve
Thread: Final release crashing | Forum: Vue
I posted the below in my "Totally confused..." thread, after having thought that things were really starting to look up due to some assistance I received from James (timefighter)...assistance that was much appreciated and does have a big impact on performance until any Posers are added...and just wanted to offer it up here as well to illustrate the severe memory leakage issues I am still experiencing...
Hmmmmmm? Still experiencing big time resource problems here. Just loaded in a recent file, "Rude Awakening" here in the Galleries, that I had done in the "working" second to last update of 6I. When working with it there, if I remember correctly my resources were somewhere in the neighborhood of 60-65%. Upon loading it into 6IF, the resources instantly go down to 11%. After letting it sit for a good 5 minutes, the resources will go back up to ~31%, but once I select anything (which in and of itself) is a 2-3 minute ordeal, they plummet right back down to 10-12% and it becomes quite painful to do anything with the scene.
Methinks this would be a good night to catch up on some reading '-)...
SteveÂ
off to find a good book, not CG related...LOL
Hmmmmmm? Still experiencing big time resource problems here. Just loaded in a recent file, "Rude Awakening" here in the Galleries, that I had done in the "working" second to last update of 6I. When working with it there, if I remember correctly my resources were somewhere in the neighborhood of 60-65%. Upon loading it into 6IF, the resources instantly go down to 11%. After letting it sit for a good 5 minutes, the resources will go back up to ~31%, but once I select anything (which in and of itself) is a 2-3 minute ordeal, they plummet right back down to 10-12%.
Steve
@silverblade...I have never been able to use those "gizmo-thingamabobs" so I just got rid of em...and use the good old fashioned method of selecting/scaling/moving.
I promised myself I would steer clear of any more soap-box action, and I plan to stick to it...but I do want to offer up this suggestion given to me by James (timefighter here in the Galleries), which I have found to be of great assistance thus far. After having done as he details below, not only do I have the ability when working in some moderate size test scenes to select/scale/move, etc items in any of the four views, I was also able to load my latest render into 6IF(yess, there are faeries...yiiikes!, but it IS a gift for my niece...LOL) that I was forced to do in 5I due to the problems I was having in 6IF. It is quite sluggish...and the resources did drop quite significantly, but at least it is a start. So from hereon out...hoping that e-on will correct these ummm...issues...'-)...i will continue to build in 5I and then "attempt" to load into 6IF to take advantage of it's special features.
Below is what James suggests...
"I had similar issues until I completly removed all traces of Vue6 Infinite from my computer and then installed a new fresh copy in a completly different directory. As soon as I did this, the similar problems that you are experiencing stopped. I suggest that you try (if you ahve not already)..."
I hope this may help someone else here as well,
Steve
Just stopped in to see what's been solved...<<Â LOL
...but I am definitely with you, Traligill...unfortunately (or maybe not) I can't locate my working 6I update...having uninstalled the pre-release to get the Final...so I'm still in 5I and tooling along quite well... '-)...
Steve
"Paybacks are hell I hear..."
Ya mean I won't be adding to my e-on POD collection in the near future? ROFL
True enuf...having been through all the previous fiascos I suppose I should know better by now, but obviously I am still a bit naive here...and too optimistic! I understand through my experiences so far that updates will break some things, but to have it totally set everything back is a bit too much for me to swallow...gulp '-)...
Anyhoo that 5 Poser figure scene in VUE5I is now up to 7 with the addition of two MilCats(with DIFFERENT texes) and still running like a charm...LOL...so much for improvement, eh 8*)? LOL
System specs aside, the fact remains that on my system that runs 5I like a charm and to a lesser extent so the VUE6I pre-release, FINAL is a disaster as I have stated in another thread here Â
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2686639.Â
So tossing barbs back and forth here is useless and pointless. The fact remains that there is something drastically wrong here, and for the life of me, I can't see how it could be system related.
Quote - I'm trying to be good Steve LOL
Â
So was I, Deb '-)
Guess it ain't working tho'..
Steve
Quote - 5 poser figures in a scene...fully textured, Hmmm.
Let's do some math.
A 4000x400 texture uses 64 megs of ram (that's a fact), how many different textures are there in your scene, what's their resolution?
Did you import figures as single mesh? Did you check the "collapse identical material" box upon object import?
You have a drop of resources after an object import, does it prevent you from working normally on the scene? Do you get warning messages about low resources? OOMs?
Â
Yes! 5 posers in the current scene, and that is not even approaching what I have done previously in Vue5...my gallery here will clearly show that...
Not all texes are 4000x4000(and that's a fact as well)...and even if the one figure I have loaded DID have such large texes, I would expect a bit better response, or AT LEAST the same response I am getting in VUE5I...
No they are not imported as single meshes as they reduces my ability to highlight certain areas of said imports...and I do collapse materials as a general rule...unless they will need further editing inside VUE...
As I stated above...I believe that not being able to select, never mind move/scale/rotate these imports would not qualify as "working normally"...
And no...I have not stuck around long enough to get OOM's...why should I bother if I can't work with a simple (out of Poser 35Mb) import which inflates to 133Mb in this FINAL FIASCO?? And yes I do realize that the import size is NOT the VUE size, but 3X the size is just a bit too much IMHO...
And please forgive me for the tone of this response, bruno....but I would greatly appreciate if it, if in the future you would not talk down to me in your replies...
I have been with VUE since 4 so I know of what I speak, but I do this for a hobby NOT to get myself worked up like this...
Steve
Hey, Deb!
Long time no see '-)...the only crashes I had in the working pre-release were with V4...NO big loss there as she has no clothes to speak of yet outside of a plethora of shoes and boots...LOL....BUT to be unable to load the simplest of pz3's is beyond me! Ahhhhhh...for the good ol' days of a working VUE4Pro, eh (with the added bells and whistles of course) 8*)!
