7 threads found!
tabbycat2 | 14 | 2532 | ||
tabbycat2 | 5 | 137 | ||
tabbycat2 | 1 | 110 | ||
tabbycat2 | 3 | 444 | ||
tabbycat2 | 1 | 107 | ||
tabbycat2 | 48 | 783 | ||
tabbycat2 | 6 | 135 |
39 comments found!
Thanks for you information and thoughts on this. Yes, I had adopted the same, unzip the files, then put them where Poser can find them. Gone are the good old days of easy installing, sigh.
Thread: Help please How do I install new items in Poser 11 Pro ? | Forum: New Poser Users Help
Wow. Ok. I guess it installs great but the operator (me) has to know which category you need to look in. This "prop" file will not be found in the "figure" category. I knew it was something simple. Ok my dress is install and it is listed as long as I click on the correct category. Oh man I have been away from Poser way too long, cause I knew this. Well, I will go make someone else's life miserable now. THANK YOU so much for all your help, all of you good enough to share your Poser knowledge with me.
Yes the runtime is in the first layer of the zip. There are other directories but runtime is there. The dress is a prop so it's a .pp2 Thinking maybe the file is messed up I tried another file and that one can not be seen in the listing.
Can my Poser 11 Pro be messed up ? This is my second copy of the program that has this problem.
This dress or item comes directly from DAZ3d And it's for Poser. I will check to be sure the files .cr2 and .pp2 but I am pretty sure they are. I will check the zip files as well but like I said it comes directly from DAZ3d and it's for poser so I am pretty sure it is properly setup. Be back soon to let you know what I found.
Ok, still not seeing my new items in Poser. Which bums me out cause you folks are so helpful and skilled in matters of Poser. I know it's something simple. I know you can make your own directories and get them listed in Poser. So I did that. I called it Poser 11 Content2 and it makes the directory as a listing but none of the files inside that directory. I used to be sane, then I found Poser, LOL.
Thread: 11.3- Install from zip | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Miss B posted at 9:30AM Tue, 10 December 2019 - #4371476
I never used the Install from Zip file function. I unzip manually to my desktop, and then move the files to the appropriate places in my Runtime. That way I know where everything is, especially since I moved some things to where I wanted them.
This is exactly like I like to install items but I have a ton of items and it's nice to get some automation to speed things up when you upgrade your computer and have to start over with installing items.
Thanks Nails60 for the link, I will definitely go there. I have used Poser for years and yet here I am acting like a Newbie. Well at least it's fun to watch the handicapped.
Thank you Nails60. Ohhhhh, ok, so it's not in the directory of Poser 11 Pro !!!!!! No wonder I couldn't find it, doh !!!
I know I have directories called Poser 11 Content and Downloads. I did a search on my hard for these directories and did not find them. So basically WTF? Would you please tell me the exact path name you use to get to your directories ? I use to be sane, then I found Poser, LOL
I decided to check my hard drive for my new item. Poser 11 Pro comes with HIvewire 3d and that shows up in Poser. Surprise to find that Lully is listed in that same directory. Proof that your instructions worked. Well hell bells, if Hivewire 3d shows up in Poser, why doesn't Lully ??? Mmmmm.
It was easy to do but it did not show up in my Poser 11 Pro. Sigh. I installed Poser 11 Pro back earlier in this year and I ran into this problem. Didn't want to spend a lot of time fixing it, so I bought another Poser 11 Pro thinking the first disc had problems because online someone said some of the discs had problems. Well, this problem showed up in the second one. So I just walked away from it. So what I am telling you is there have been no parameter changes done to my Poser. All I did was install it and never got to use it. I did try going back to Poser 7 my favorite but it will not run in Windows 10.
So I am shocked your instructions did not work because I ran it at default. It's got to be the path name hence, the reason I want a files tree for Poser 11 Pro.
Thread: Can Poser Pro 11 license be installed on more than one machine? | Forum: Poser - OFFICIAL
Ok as promised I have returned OMG those install files you have to download work great. I have Poser 11 Pro up and running and I just can not thank you fine folks for being so helpful !!!!! Thanks and more thanks.
Tabbycat aka Alice
I long for the olden times when you didn't have to go through hell to run your software programs. LOL Ok, i went to all the links and downloaded the files. Hope this works. I will return and let you know. Again, thanks to all.
