32 threads found!
tantarus | 4 | 52 | ||
tantarus | 2 | 177 | ||
tantarus | 0 | 24 |
(none)
tantarus | 2 | 85 | ||
tantarus | 1 | 33 | ||
tantarus | 0 | 26 |
(none)
tantarus | 1 | 29 | ||
tantarus | 4 | 179 | ||
tantarus | 5 | 210 | ||
tantarus | 14 | 224 | ||
tantarus | 10 | 271 | ||
tantarus | 6 | 60 | ||
tantarus | 0 | 10 |
(none)
tantarus | 9 | 52 | ||
tantarus | 0 | 11 |
(none)
672 comments found!
This way its just PITA for texture artist, but they trained already to deal with that. Head can be decapitated at neck and cover squre map completely if mapped properly.
Open your mind and share the knowledge!
Thread: Pornographic scenes. | Forum: Poser - OFFICIAL
Quote - So many poser artists are using this software to make pornographic scenes.
What is your opinion?
Â
To make a well made erotic (porn) scene in Poser, artist need allot of knowledge of human anathomy, lighting, camera setup, composition, rendering, post work. It needs allot of creativity and practice to pull well made erotic scene with Poser generic manequins and plastic skin.
Artist make art, viewer see what he want to see.
But this thread is just trolling anyway, so its pointless to say more ;)
Thread: Need to create wireframe graphic of uncrumpled paper | Forum: 3D Modeling
Make plane primitive in C4D, make it editable with "C" key. In Points mode, under Structure menu use Brush tool. On Right side you will see various modes for brush tool. Twister for example will make crumpled paper fast, just lover the strenght and play with it. C4D UI is very user friendly so you should not have any probs..
C4D Demo can be used in full for 30 days. You have option in render settings called "Cel renderer", it will render wireframe only in color of your choice. Its located under effects - Post effects :)
Thread: How to get paths/pen tool to obey? | Forum: Photoshop
Thread: Modeler Seeks Rigger | Forum: Poser - OFFICIAL
RorrKonn you know nothing about me, so be nice and stay polite.
Â
Quote - I know a few ,very few ,CGI Artist has made $50,000.00 at turbosquid. With rigged ,map ,textured for Autodesk Max charaters.
If not rigged ,map ,textured for Autodesk Max charaters ,few sells.
as far as I can tell.
Â
Instead of talking nonsense and making fool out of your self. Learn, give constructive opinions in your limits, and dont attack others ;)
JonnyLee... design, sculpt, retopo, texture the model. Render WIPs and then ask for rigger, if someone is interested you will have something to show. To be on safe side, show those WIPs only in private to possible rigger.
But best solution would be not to look for shortcuts and "easy money", but to rig it by your self. Poser rigging system is ancient and tedious, but its needed if you want to sell poser content.
Thread: Does UV'ing make you crazy too? | Forum: 3D Modeling
I enjoy UV mapping, its relaxing. Easy models are boring, more challenging more fun lol :tongue1:
Thread: Need HELP placing Logos On clothing | Forum: Poser - OFFICIAL
If you already have BP, use projection painting to add logo. You don`t have to worry about UVs at all, 3DKiwi have simple tuts at C4Dcafe that will explain you basics.
Thread: grouping in other apps than poser | Forum: Poser - OFFICIAL
After you have done groups in external app. Import OBJ, in grouping tool click on spawn props and delete the original OBJ. You will have model separated into pieces according to your groups, its ready for rigging.
Thread: WIP: Simple Morphing Chess Piece - Advice On The Knight? | Forum: 3D Modeling
This is big progress, you have very good base and enough of points to round it up a bit more. Now UV map it and make textures that will bring him to life. I like the shape of it, nice work.
Thread: Question for modellers | Forum: Poser - OFFICIAL
Shoulders are problematic area in Rigging, and muptiply that with Poser primitive rigging there is not much help. Modeling a shirt is modeling 101, so its not the model but rigging limitation. As for crouch area, that is paying attention to details. If modeler want to make quality job it will pay attention to that area too ;)
Thread: Probably a simple solution | Forum: Photoshop
If its white background, simply put whole image above concrete without deleting anything. And set the blend mode to Darken, it will remove white color and leave the piece you need.
Thread: How do I change an image's color? | Forum: Photoshop
There are number of ways, but quickest would be to use Quick mask mode and paint the selection around house. CTRL+J to copy house to new layer, use variations to color it pink, and finally use Color blend mode to make it more realistic. Hope that helps ;)
Thread: DAZ UV's | Forum: Poser - OFFICIAL
