68 threads found!
tomasball | 13 | 360 | ||
tomasball | 2 | 120 | ||
tomasball | 3 | 134 | ||
tomasball | 7 | 403 | ||
tomasball | 3 | 173 | ||
tomasball | 3 | 189 | ||
tomasball | 9 | 313 | ||
tomasball | 6 | 178 | ||
tomasball | 3 | 120 | ||
tomasball | 0 | 59 |
(none)
tomasball | 1 | 93 | ||
tomasball | 5 | 209 | ||
tomasball | 6 | 261 | ||
tomasball | 5 | 182 | ||
tomasball | 2 | 152 |
72 comments found!
Excuse my ignorance, but I'm having trouble deleting that file. I found it in my windows explorer, and tried to delete it, but was notified that I needed permission. I really don't know my way around Windows 10
Thread: cloth room question | Forum: Poser - OFFICIAL
I apologize for causing irritation. This is really the first time I have ever run across the term "hybrid clothing", and I just checked to make sure I didn't miss it in the manual...I didn't; the Poser Pro 2014 manual does not have the term "hybrid clothing" or "hybrid cloth", and it makes no mention of clothifying individual body parts. Please be sure I did search this subject before inquiring here...but I didn't know enough to google "hybrid clothing". Now that you explained that when you said "clothify the original cr2" you meant to clothify the individual body parts, I understand, and can take it from there. Thank you, and again, sorry for causing irritation.
"Clothify and sim the original CR2." There seems to something here I'm completely ignorant about. How do you clothify a Cr2?
I don't understand. I didn't think the cloth room would let me clothify an entire figure. I'll double check that in about an hour.
Thanks Glitterati3d, but I'm still running into problems. Please back up and describe how you use the original shirt to create the .obj that will be clothified. I'm sure i'm making some wrong combination of selections on the export dialog.
parkdalegardener, I have tried that, and I do get a morph dial added to my shirt, but when I use it, the shirt just scrambles. Is this something you have successfully done, and if so, please talk me through it in detail. Kalypso, since there is a "load full body morph" item in the menu, and the manual says you can add fbms made "in third party programs", it seems to me there should be a way to do this.
Thread: what software will do this? | Forum: Poser - OFFICIAL
Thread: texture mapping fundamentals question | Forum: Poser - OFFICIAL
No, I don't want to redistribute. I just thought there might be a program that would refit a texture to an new map.
Thread: IK question | Forum: Poser - OFFICIAL
Right, that's what I'm talking about. The "goal" doesn't move unless you drag the figure past the maximum extension. Is there something that can be set to prevent you from dragging the figure past the maximum extension, or adjusting how hard you have to drag?
Thread: unwanted smoothing | Forum: Poser - OFFICIAL
Thread: September/October Bryce Challenge - 'DAMAGE' - Vote Now - Vote Here!! | Forum: Bryce
Thread: Poser heaven has arrived? | Forum: Poser - OFFICIAL
After some thrashing around, I have the importer working, and getting some fun results, but...
the imported figure can't use inverse kinematics...that option is not available from the menu. Is that just the way it is, or am I doing something wrong?
Thread: smart props? | Forum: Poser - OFFICIAL
Well, I got it to work. Apparently, if you use the "select subset" button to make sure you have the right prop, that eliminates the smart prop option. How odd.
Thread: Poser Pro 2014 Executible File Stopped Working | Forum: New Poser Users Help
