5 threads found!
vertotegro | 2 | 109 | ||
vertotegro | 0 | 21 |
(none)
vertotegro | 0 | 18 |
(none)
vertotegro | 0 | 47 |
(none)
vertotegro | 7 | 188 |
5 comments found!
Thread: V3 males - What about "Willy"? | Forum: Poser - OFFICIAL
Making the genitals from digiport fit is very easy, as there are no pieces that have to match 100%. As for textures, the texture that comes with it is reasonable. I have used this item with a number of body textures, a little tweaking of the base color usually produces the needed results. Plus that part of the body never has a 100% color match to the rest of the body. A nother trick is to make the piece where it attatches a little transparent to get better blending.
Even if they do it will not be as good as the one at BBay from Digiport. http://www.bbay.com/cfwebstore/moreinfo.cfm?Product_ID=493 I think yop will have to sighn up at BBay to be able to buy it, but it is worth buying.
Thread: V3 morph injection | Forum: Poser Technical
It would seem that with multiple runtime directories the system spends most of its time looking for the files, like when jou are missing a texture file and it takes for ever to load the file. Now multiply by several hundred missing files and you get 22-27 hours of loading
In the end the reason my machine took 27 hour to inject the morphs, was the multiple runtime directorie I had under Poser 5. Reinstalling under the main Poser 5 diretory and disabling the others, reduced load time to 2 minutes.
