I use this scaling a lot with tiling textures and, yes, I have noticed the results are not always logical. I think it may depend on the way the item was uv scaled to begin with. I was diminishing patterns to show up more like an all over pattern-- worked great on the skirt and when I got to the top, i had to Increase just to have exact same pattern seen. I usually worked around with 0.5, rarely went too much farther than .3 and occasionally had to go to 2.5. I think it's a great tool, just doesn't always works exactly as you would think-- and the changes are not reflected at all in the display model. It is in the little image map thumbnail-- but that is pretty small to go by. Emily
No no, can you imagine which way the piece of cloth, this loin would have been cut from, was layed just before it was cut? I wish it were utrned 90 degrees before cutting. You need to be able to see the fine way in which the cloth would have been weaved together. I can detect a small pattern that runs horizontal between gravities folds of the cloth. I think these would look more attractive if they ran verticle! = )
I loaded a bump and then made its tile much smaller by changing the U and V scale to .1, but I do'nt know what either are. Actually I'd like to make the horizonal effect a bit finer than the verticle, but am not getting the results I expect. = )
