Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 24 11:54 pm)
Absolutely no idea whatsoever. Sorry, but I can't think of a single reason for this to happen, apart from some blindingly obvious mistake. Let's start from the beginning. You made a prop. Does it save OK without the morph? Next, you import the morph through Properties, right? Does the morph dial appear? I suppose it does, because the morph works. You then save the prop to the Prop Library, correct? Not any other library? (I'm clutching at straws here). Have you tried saving the prop + morph, then opening the pp2 file in notepad to see if the morph channel is there? Can't think of anything else at the moment. mac
I am also a bit mystified by this one. The word "morph" can cover a few things, but I assume that you mean a morph target loaded via Object>Load Morph Target. If the MT works on the prop I can't see any reason why it should not save with the prop. I am going to make a stab in the dark here. If you morphed the prop by applying two or more morph targets, or if you morphed the prop by applying a magnet, then you have to use Object>Spawn Morph Target, to actually create your new MT in the prop. Other posibilities are that: 1. You had the wrong item selected when you spawned the MT. 2. You did not morph the prop, you scaled it, scaling will not save to an MT. 3. There was some glitch in your system and the file did not save corectly. 4. The MT was created, but you have not expressed it by turning its dial.
Ok I created the prop in Max.Then I imported it into poser.Then i created the morph in max and imported that obj file into Poser as a morph for the prop. Dial appears,Morph works,save it again, morph appears on prop.Great...create another morph, dial appears,morph works save it,open it agin morph dial not there .First one still there.Try again same thing..not there.
Brandonc, you can have as many morphs as youlike in a pp2 or cr2. If you mean "can you load a number of morphs at once" the answer is yes. You can put a number morphs in a pz2 (pose) file, then apply it to your character, but there is a catch, you need to have channels in the character's cr2 file whos names match the channels in your pz2. This is called Delta Injection, or Morph Injection, its what Victoria 3 uses, but it can be used on any figure.
Its a bug Brandonc, i think its an OS thing or something coz i get it all the time and in P4, pro pack and P5...last one i save it with 4 morphs but only 2 would show up every time, in the end i took them off my XP machine and did it on the ME laptop, hense the OS suspicion...anyway sorry i don't have a fix, i hope someone else has one coz its damned annoying..Steve
Ive made a prop,and when i add a morph to the prop the morph works but when I save the prop it wont save the morph with it..Any Ideas?
