Mon, Jan 20, 11:40 AM CST
Vue F.A.Q (Last Updated: 2024 Dec 30 8:14 pm)
Subject: Vue4Pro works fine now! :o)
Tiny ( ) posted Wed, 08 October 2003 at 3:27 PM ยท edited Thu, 11 July 2024 at 9:23 PM
After 2 reinstalls and ignoring the "your graphic card is no good" comment, everything works very well.
I really like this program! Tree fixer department is fun and easy. And being able to actually see all the objects is great.
Next I get on to the net rendering and see how/if that works.
There isn't a day without new excitements! ;o)
SAMS3D ( ) posted Thu, 09 October 2003 at 8:34 AM
wait, you mean you ignored the graphic card thing during install? maybe I should do that, cause it use to work fine. Did you do an unistall or remove programs when you took it off. Sharen
Tiny ( ) posted Thu, 09 October 2003 at 11:52 AM
It seemed to be quite messed up so it refused to uninstall properly. So I tried to clean up what I could. The second install didn't work either but the third I installed "over" the current install. ... did that make sense...? And so it worked.
About the graphic card: Gebe gave me the advice not to worry about the message about card being no good. It should work with the modell I have. And so I answered no when asked if I wanted to turn off openGL. And then I unchecked the 'check graphic card at start up'. No problems since. :o)
SAMS3D ( ) posted Thu, 09 October 2003 at 1:18 PM
Thank you so much for this info, I will do a reinstall later if I have time and will do the same with the open Gl...I have been trying to find out what kind of graphics card is allowed, but can't seem to find that info. but thank you again. Sharen
