Mon, Jan 27, 6:53 PM CST
Renderosity Forums / Bryce
Welcome to the Bryce Forum
Forum Moderators: TheBryster
Bryce F.A.Q (Last Updated: 2025 Jan 23 6:01 pm)
[Gallery]     [Tutorials]
THE PLACE FOR ALL THINGS BRYCE - GOT A PROBLEM? YOU'VE COME TO THE RIGHT PLACE
Subject: The Example
Acorncatcher ( ) posted Tue, 18 November 2003 at 8:27 AM · edited Mon, 27 January 2025 at 6:49 PM
Ok so here is what I was aking earlier, I am making a gold coin to illustrate my point.The image was made in Photoshop 7, 1024 x 1024 at 500ppi, is that still not big enough!!?? or am I doing somthing wrong in bryce (I suspect this is the case!).
erosiaart ( ) posted Tue, 18 November 2003 at 8:32 AM
Check the anti aliasing section..seems that's the probs... make sure anti alaising is on. but..er..um..I actually like the way the coin is now!! tell me I'm nuts!
brittmccary ( ) posted Tue, 18 November 2003 at 9:05 AM
What's your terrain settings? Set the terrain resolution in Bryce before you apply the image in the terrain editor.. (see a post from me last week :)
brittmccary ( ) posted Tue, 18 November 2003 at 9:07 AM
Acorncatcher ( ) posted Tue, 18 November 2003 at 9:08 AM
Terrain Settings 1024, anyhigher and my computer starts to hurt.
Acorncatcher ( ) posted Tue, 18 November 2003 at 9:10 AM
BEFORE!!!!! ARGHHHHHHH all that time! :)
brittmccary ( ) posted Tue, 18 November 2003 at 9:13 AM
lol Trust me! I recognized your agony, and knew the remedy!!! Ouch... sometimes it hurts to learn the hard way!!
Acorncatcher ( ) posted Tue, 18 November 2003 at 9:15 AM
I CAN TRULY SAY.....I HAVE LEARNED THE HARD WAY :)
GROINGRINDER ( ) posted Tue, 18 November 2003 at 1:33 PM
I think ppi only matters if you are printing an image. I use 72 ppi for everything I take into Bryce with no problems.
shadowdragonlord ( ) posted Tue, 18 November 2003 at 5:37 PM
Aye, the DPI (PPI) settings you posted, "1024x1024 at 500 ppi" are irrelelvant in this case. 1024x1024 at 500 DPI would produce an image about 2 inches by 2 inches, if you were to print it. Printing resolution, inside Bryce, means nothing Acorn. If you want a smoother coin, you simply raise the original resolution up to 2048 or godforbid 4096. But unless you plan on only having one or two coins in the scene, this method of modeling is entirely impractical.... Having a coin with MILLIONS of polygons isn't too efficient. Try using boolean modeling, if you are only using Bryce. You should be able to make this coin with just a few objects...
Zhann ( ) posted Tue, 18 November 2003 at 5:55 PM
You DON'T have to select the resolution BEFORE you import, once you import the PS image if it doesn't look okay you can INCREASE the resolution by selecting the res you want and then hit the 'APPLY' and wait a few seconds and Bryce will apply the new res..... DPI is only good for print res, not terrain or lattice res.
Bryce Forum Coordinator....
Slakker ( ) posted Tue, 18 November 2003 at 6:56 PM
Didn't i say that in the last thread? No one listens to me around here...
shadowdragonlord ( ) posted Tue, 18 November 2003 at 8:44 PM
(smirks, grins at Slakker!)
Zhann ( ) posted Tue, 18 November 2003 at 11:24 PM
I said it in the last 3 threads about this but no one reads them....:
BOOMER ( ) posted Wed, 19 November 2003 at 3:46 AM
I listen, Zhann. I'm on pins and needles to see what you'll come out with next. hehe
Because I like to blow $%&# up.
Don't fear the night.  Fear what hunts at night.
Zhann ( ) posted Wed, 19 November 2003 at 3:54 AM
:P
