Mon, Oct 21, 10:39 PM CDT
Renderosity Forums / Poser Python Scripting
Welcome to the Poser Python Scripting Forum
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
We now have a ProPack Section in the Poser FreeStuff.
Check out the new Poser Python Wish List thread. If you have an idea for a script, jot it down and maybe someone can write it. If you're looking to write a script, check out this thread for useful suggestions.
Also, check out the official Python site for interpreters, sample code, applications, cool links and debuggers. This is THE central site for Python.
You can now attach text files to your posts to pass around scripts. Just attach the script as a txt file like you would a jpg or gif. Since the forum will use a random name for the file in the link, you should give instructions on what the file name should be and where to install it. Its a good idea to usually put that info right in the script file as well.
Subject: P5 - Mat copier?
soulhuntre ( ) posted Mon, 02 February 2004 at 11:55 PM · edited Fri, 27 September 2024 at 7:04 AM
This came up in another thread. Is there/could there be a Python script that would allow me to select a source material zone, and then select the target material zones so that Python could copy shader settings from the source to the target(s)?
ockham ( ) posted Tue, 03 February 2004 at 12:46 PM
If you mean selecting by group name (FaceSkin, Fingernails, etc) then it should be possible. It's certainly possible to copy the whole 'Material' from one group to several others in P4. This should carry the shaders along with the Material in P5. (I don't know but a quick test will answer the question.) Python doesn't have DIRECT access to the P5 nodes. But if you mean selecting visually by mouse, then it's just about impossible.
My python page
My ShareCG freebies
soulhuntre ( ) posted Tue, 03 February 2004 at 5:12 PM
No, by group name is just fine :)
