Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2024 Sep 08 8:54 pm)
Freeware 3D Modeling Software Links:
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
"What 3D Program Should I buy?" Not one person here can really tell you what's best for you, as everyone has their own taste in workflow. Try the demo or learning edition of the program you're interested in, this is the only way to find out which programs you like.
well, considering the original modellers used random parts from stock car models, etc., I could see modelling all those little doodads could take quite a while. If you continue the present level of detail on the rest of the ship, it will be some mesh..keep going with it.
In the end you will have a very nice show piece for your portfolio. If intend to actually use this for projects though, would recommend doing multiples, each with different levels of detailing, or with heavy detailing only on the sides facing the viewer... so the most detailed can be used for up close beauty shots... while when seen ever farther away, hints of detailing - might be all that's needed, and can then help reduce render times. Unless of course you have one hell of a computer or a render farm of them... As mentioned on your gallery posting. Greeble on. It's looking mighty fine.
Great progress, look forward to seeing it finished! I wonder if displacement mapping could be used instead of modeled detail or bump mapping. Are there applications that can do displacement mapping without costing huge amounts of additional render time? Real time displacement mapping will be a major new feature in the soon to be released ZBush 2.0; however, ZBrush is not an animation program (yet!) Chris
hewsan - that's good advice, but in this instance I'm just modelling the 'G' for fun, so render times aren't really an issue. It's occurred to me however, that I could use renders of the detailed version to generate texture maps for use on a lower-rez version (that way I could build myself a fleet LOL)
numanoid - I'm using a P3 800Mhz with 512MB of RAM - so I'm not exactly a power user myself LOL. I'm hoping that the final mesh will be less than 200,000 polys, which will make it smaller than the Humvee model produced by PoserWorks. I use this as a benchmark, as it's the biggest model I can work comfortably with on my system.
Thanks to everyone for the input and kind words, it's much appreciated.
