Sat, Jan 11, 9:01 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 11 12:18 am)
Subject: Joining Objects in Poser
d4500 ( ) posted Wed, 21 April 2004 at 12:28 PM ยท edited Wed, 27 November 2024 at 12:11 AM
Does anyone know how to join (group) two or more objects togather? For example: joining squares to make a rectangle?
mateo_sancarlos ( ) posted Wed, 21 April 2004 at 1:01 PM
Geep must have a tutorial on this. If not, just arrange all the objects, then export as wavefront.obj file.
d4500 ( ) posted Wed, 21 April 2004 at 1:52 PM
Hi. It works great. Thanks. But now I'm curious. How do you get to add a different material to each square? I saw it somewhere but I don't know how to do it. For instance a house is made up of different objects but you can add one color for the roof, another for the walls and doors and windows.
diolma ( ) posted Wed, 21 April 2004 at 2:25 PM
Add the materials before you export. Then re-import. Materials should stay attached.
d4500 ( ) posted Wed, 21 April 2004 at 2:38 PM
Gee... I wanted to be able to add AFTER you import - I guess it can't be done. It would be nice though. Unless you can change material afterwards.
d4500 ( ) posted Wed, 21 April 2004 at 2:56 PM
I know you can change material globally, but I don't know how you can change them individually per object.
maclean ( ) posted Wed, 21 April 2004 at 2:58 PM
You can use the grouping tool to assign materials. Open it and select the polygons you want, then click on the 'Assign new material' button. (Very vague instructions because I haven't used this tool for several years) Also, check Geep's tutes for 'grouping tool' mac
maclean ( ) posted Wed, 21 April 2004 at 3:00 PM
PS It's a lot easier to do this in uv mapper. If you have the free one, select the parts you want, then go to Menu> Tools> Assign> Material and give the material a name. Resave the obj and imprt it to poser. mac
d4500 ( ) posted Wed, 21 April 2004 at 3:36 PM
I did it. I did it. I did it. I assigned each square a material using the group tool. Thanks.
maclean ( ) posted Wed, 21 April 2004 at 5:48 PM
Great. Glad to be of help. mac
