Mon, Feb 17, 10:32 AM CST
Renderosity Forums / Fractals
Welcome to the Fractals Forum
Forum Moderators: Anim8dtoon, msansing
Fractals F.A.Q (Last Updated: 2025 Jan 21 7:59 pm)
Subject: Preview Transform Variations script
Encrypted ( ) posted Sun, 13 February 2005 at 10:50 PM · edited Sun, 28 July 2024 at 1:10 AM
Works well with flames using a low number of transforms (3 to 4).
Hopefully this will be useful to someone.
Check out http://www.context.cx/download.html
Makes a good script editor for Apophysis.
Tip: try the Object Pascal syntax highlighter.
The dashed line below should not be wrapped to two lines.
If it is, then some of the code may be wrapped incorrectly.
Zeros all variation values on selected transform and then
steps through variations entering a random value.
Status bar will show the Variation, value, and Transform number.
Click cancel or hold down the Enter key to exit script.
Using Undo or Ctrl-Z twice will remove update changes.
0anon0 at earthlink.net
tform := 1;
if not InputQuery('Start Transform?','Transform #',tform) then exit;
With Flame Do
Begin
SampleDensity := 50;
Oversample := 1;
FilterRadius := 0.1;
End;
SetActiveTransform(tform - 1);
with Transform do
begin
for i := 0 to NVARS - 1 do
Variation[i] := 0;
end;
for k := 0 to NVARS - 1 do
begin
Transform.Variation[k] := random;
v := Transform.Variation[k]
Preview;
ShowStatus('Var' + '=' + IntToStr(k) + ' ' + 'Value' + '='
  • FLoatToStr(v) + ' ' + 'Transform' + '=' + IntToStr(tform))
    up := False;
    if not InputQuery('UpdateFlame?',
    '0 = False/No 1 = True/Yes',up) then exit;
    UpdateFlame := up;
    If up = True then Exit ;
    If Stopped then Exit ;
with Transform do
begin
Variation[i] := 0;
end;
end;
{0 Linear
1 Sinusoidal
2 Spherical
3 Swirl
4 Horseshoe
5 Polar
6 Handkerchief
7 Heart
8 Disc
9 Spiral
10 Hyperbolic
11 Diamond
12 Ex
13 Julia
14 Bent
15 Waves
16 Fisheye
17 Popcorn
//18 Exponential
//19 Power
//20 Cosine
//21 Sawtooth}
DreamWarrior ( ) posted Sun, 13 February 2005 at 11:04 PM
Ohhh, I like it. Thank you very much!
My crafts - My Freebies - My Store - Delightful Arts
