Vue F.A.Q (Last Updated: 2024 Dec 30 8:14 pm)
Well, the easiest is to do it with two keyframes for the whole figure. #1 is where the figure should appear and #2 is ONE FRAME EARLIER outside the camera view. I explain it in this order because this makes it easier to deal with it. First to position it properly and then shift it out of sight.
I'm sure there's a simple way to do this, but I can't figure it out. I'm trying to create a scene in which an figure, after a few moments, suddenly appears in a flash. The problem is that when you import a Poser figure, it appears immediately in the scene. I would have to make all the materials,(and It's quite a few) transparent at the beginning, and make them zero transparent at the point I want it to appear. There must be a way (perhaps using the timeline) to import a Poser object and have it not appear in the scene until the point I want it to. Any help appreciated.
