Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 4:13 pm)
If you updated, it means you have the "better" version, and it's probably the Vicki Map and the Vicki Map 2. This is just from memeory though, but when I updated, which was only two days ago, I had wondered the same, but had made a backup first, then deleted the Vickies, and ran the update again, and, IIRC, it was what I mentioned above which was placed into my Zygote People folder. But I can't be absolutely certain, because since then I have renamed them. What you should ALWAYS do before anything like this is to abck up your .cr2's and your geometry .obj files. ALWAYS! But, rest assured, that I've been using the "new" Vickie all day, and there are no problems at all that I've found with her. I know I have the update, I just can't remember the exact names. If you really want to know, make a copy of all the .cr2 files, put them somewhere "safe", delete the older ones from your Zygote People folder and then run the updater .exe again, and then you'll have your answer.
Please don't laugh out loud, but between the zygote updates and the Vicky CR2 fix, I have the following: (Can you tell me which ones I can delete?) Name Size Vicki - M 9.69 mb Vicki Map 8.90 Vicki Map 2 8.90 (1-12-01 z update) Vicki 8.89 Victoria Map 2.78 Victoria Morphs 403 8.66 (finger fix) Victoria 2.78 Don't the files overwrite the original on an update from Zygote? I'm feeling pretty silly... Thanks in advance
