Sat, Jan 25, 1:24 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 6:22 pm)
Subject: Poser6 bug. James genitals bend problem.
Badco ( ) posted Sun, 10 April 2005 at 12:49 PM · edited Fri, 10 January 2025 at 8:58 PM
With the Genitals selected for James, if you move the bend dial it just distorts the penis instead of bending it. I believe that the spherical falloff zones are messed up.
geep ( ) posted Sun, 10 April 2005 at 2:07 PM
It's not a bug ... it's a "feature." Someone told me that .......... once. ;=] Have you tried using viagra?
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sun, 10 April 2005 at 2:11 PM
Try using the morph, not the "bend." ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Badco ( ) posted Sun, 10 April 2005 at 3:09 PM
But the morph, only goes so far. After applying the morph is when I want it to bend. Don't aks !:^>
geep ( ) posted Sun, 10 April 2005 at 3:17 PM
Ok, I won't. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
STORM3 ( ) posted Sun, 10 April 2005 at 4:06 PM · edited Sun, 10 April 2005 at 4:08 PM
Because the genitals are a body part they have the same translation dials of any other body-part (automatic unless they are removed or hidden from the cr2). They are not meant to be used (although you can use them - with care), the morphs are the main means of generating change. If you want greater flexibility it is a simple matter to create morphs in a 3rd party modelling app or by use of magnets.
Message edited on: 04/10/2005 16:08
Badco ( ) posted Sun, 10 April 2005 at 4:54 PM
Please don't take this the wrong way but that is totally ludicrous ! If that were true then if I wanted to bend the foot I would use a morph instead of just using the "bend" dial ? Whateva !!! I didn't put this message up for debate or for a solution. I am just reporting a bug. The spherical falloff zones for the bend dial on the genitals are messed up. It can be fixed. When I fix it I will post the numbers to fix the dials. Nuff said !
DarkErebus ( ) posted Sun, 10 April 2005 at 7:12 PM · edited Sun, 10 April 2005 at 7:13 PM
Very important must be sad
Message edited on: 04/10/2005 19:13
Badco ( ) posted Sun, 10 April 2005 at 7:40 PM
Ok, here is the fix: 1. Insert James and select the genitals. 2. Open the Joint Editor and select Bend. 3. Select the outerMatSphere and input these numbers in the properties box. xTran.. 0.137 yTran.. 3.122 zTran..-0.441 4. Select the innerMatSphere and input these numbers in the properties box. xRotate.. 55 degrees xTran.. 0.000 yTran.. 2.808 zTran.. 0.606 5. Now move to the inclusion area on the joint editor and input these numbers. incl.. Dyn B = 270.544 incl.. Dyn C = 127.099 That should do it. Its not perfect but with the morph and these settings for the bend dial it should be good enough.
movida ( ) posted Sun, 10 April 2005 at 9:04 PM
thank you sooooo much, Jessi :)
