Wed, Dec 4, 9:11 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
Subject: Funky Clouds
bcbii ( ) posted Wed, 24 August 2005 at 3:10 PM · edited Wed, 04 December 2024 at 8:48 PM
Hello, Last night I was fiddling around with Vue (running vue 4 d'Esprit). I added a cloud plane to my scene, and to it applied a volumetric cloud texture (I tried just about all of them). Everytime I ended up with a technicolor sky (swirls/bands of rainbow colors). I am assuming that I am doing something wrong. It is difficult for me to explain my method as I am not sitting infront of vue at the moment. Maybe somebody has had the same problem and could help me out... Thank you
sittingblue ( ) posted Wed, 24 August 2005 at 9:38 PM
I don't believe you can successfully use volume material on a 2D plane. I think the volume clouds are for clouds made using spheres, cubes, and other 3d meshes with the volume material applied therein.
Charles
bcbii ( ) posted Fri, 26 August 2005 at 1:45 PM · edited Fri, 26 August 2005 at 1:46 PM
Ahh that would make sense, as a plane has no volume, you can't put something with a volume into the plane. Anyway, so are the volumetric clouds designed for a more in the clouds view? For example a rendering of a plane flying through clouds?
I am assuming that volumetric clouds can also be used for for, just apply the material to a sphere that is close to the ground?
Thank you
Message edited on: 08/26/2005 13:46
sittingblue ( ) posted Fri, 26 August 2005 at 9:51 PM
The best work I've seen with volume clouds are when the clouds are hugging a mountain or lying close to the ground. Your welcome.
Charles
