Forum Moderators: Wolfenshire Forum Coordinators: Anim8dtoon
Photoshop F.A.Q (Last Updated: 2025 Jan 14 1:57 am)
Our mission is to provide an open community and unique environment where anyone interested in learning more about Adobe Photoshop can share their experience and knowledge, post their work for review and critique by their peers, and learn new techniques while developing the skills that allow each individual to realize their own unique artistic vision. We do not limit this forum to any style of work, and we strongly encourage people of all levels and interests to participate.
You can make 5 to 10 different images with your text and the glow effect. Use the glow effect at different "GLOW" levels on each image. I did this with a dog for a buddy only I used 10 to 15 frames (images) in between fade Up and Fade down so it would look smooth. Play around with it. It will take a little time, but you will be proud of yourself when you finish.
Merry Christmas,
Thelby
Message edited on: 12/04/2005 14:30
I would rather
be Politically Incorrect,
Then have Politically
Correct-Incorrectness!!!
Ah, doing each frame with a slightly different setting is the long way around. You can get the same results by changing layer effect setting each frame. Create new frame, open up your outer glow (layer effect) and move the slider a little. Repeat this for each frame and there you go;)
Example:
All done with layer effects only, not only will this save you heaps of time and effort, it also looks better in the end because you have control over the setting and it also is a lot more smoother. Hope it helps;)
I never intended to make art.
I am trying to make an outerglow pulseate in imageready. I have applied it to some text and would like it to pulse but can't figure out how to do it. By changing the opacity I can make it work but on the glow and the text and not just on the glow. anyone know how to do it?
