Forum Coordinators: Kalypso
Carrara F.A.Q (Last Updated: 2024 Sep 29 9:32 am)
Visit the Carrara Gallery here.
Chances are you need to turn up the settings for the indirect lighting in the render room. There are several switches that you can flip to change the results but I would start by setting the quality higher than the default and also decreasing the pixel accuracy. You will have to pay for it in render time but you can get the results to be a lot better than what you have here. You can find the settings I'm describing when you click on the icon at the top which takes you to the room where you render the final images (icon all the way to the right up where the wrench, film strip, paint brush etc are). There will be a tray (panel) on the right which will have the render settings in it. -Kix
-Kix
You know what, with this one, I'm with GWeb. The only thing I read the manual for is power tools because I can lose a body part. Everything else is fun exploration!
Regards,
Eric Winemiller
Digital Carvers Guild
Carrara plug-ins
Eric Winemiller
Carrara and LightWave
plug-ins
I'm getting "blotchy" renders. This one has one light source. If you need more details of current settings (pretty much default) I can provide them. Can someone give me a hint on why it's blotchy?
Thanks
Phil
Phillip Drawbridge
Website
Facebook
