Wed, Feb 26, 5:40 AM CST
Renderosity Forums / Bryce
Welcome to the Bryce Forum
Bryce F.A.Q (Last Updated: 2025 Feb 17 1:22 pm)
[Gallery]     [Tutorials]
THE PLACE FOR ALL THINGS BRYCE - GOT A PROBLEM? YOU'VE COME TO THE RIGHT PLACE
Subject: Export issues
HybridSoul ( ) posted Fri, 23 March 2001 at 7:33 AM · edited Thu, 06 February 2025 at 8:04 AM
hi all first thing im not a bryce user but i have some bryce models that i would love to make lightwave ones ( to lazy to recrete them ) so i was wondering dose bryce export to .lwo
Doom Dancer ( ) posted Fri, 23 March 2001 at 8:07 AM
Hi Hybrid...as far as I know, It doesn't. Bryce only exports in three(supose to be four) file types: .RF .DEM and .PGM (the fourth is supposed to be .OBJ) And the only model type you can export are Terrains.
RimRunner ( ) posted Fri, 23 March 2001 at 9:45 AM
There is an update on Corel's site which does add export to other formats. I use Truespace and that is one it added. 3D Studio I believe is another format it will handle. (not at my machine at the moment, will check back). Nice thing is, I believe Lightwave will import 3DS, COB and OBJ as well. So between these, you should be able to find a common format. If you want the material selection to be "retained", try 3DS. It will export BMP files along with the object which can then be re-applied. (is it bmp or jpg.. damn, have to check that as well. LOL). And there were some steps on how to export some things other then terrains.. check the archive for this forum.. it's a common question.
The doctor says I have way too much blood in my caffeine system.
HybridSoul ( ) posted Fri, 23 March 2001 at 9:51 AM
cool thanks for the info will get someone to try it for me and lightwave wont do .cob files wish it did but i do have truespace ( free version ) so thats not a prob and will check though the threads
RimRunner ( ) posted Fri, 23 March 2001 at 11:13 AM
Ok, this is the export list for terrains (still trying to find the info on other objects.. but that's a pain).. after the patch. Note: Some people have problems with the 'Corel' 4.x patch, go to www.brycetech.com for the MetaCreations 4.x patch. (if you have the meta version of Bryce). Anyway, the screen-shot above is the export list. :) As you can see, there are a large number of options, so you should be able to find something that will port over. And yes, on terrains, the textures, bumps and such will come out as BMP files if you do 3ds, cob, etc. (depending on the format, you can get a number of files, just used layered textures on the other end to recapture the look. Bryce does GREAT at a distance. In TS, when I pull the textures in and place a camera near ground level, it's very pixilated. Nasty and ugly. Some Photoshop love will cure this problem :) Not to mention you can change the format to JPG or TIFF for file size issues.)
HybridSoul ( ) posted Mon, 26 March 2001 at 10:11 AM
cool thanks for the info i will retexture all the models anyway and well i love my photoshop :-} just needed to know if i could get them models in to lw now to just get my mate to convert them for me :-}
